Question about LG Heating & Cooling
How to reset split PCB - LG Heating & Cooling
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
www.youtube.com/watch?v=i30rEvyuDKs
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
My LG split Ac is running some times but some times not working and showing error code CH09
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB.
Multi V= Indoor unit EEPROM error - Replace the indoor unit PCB, and then make sure to do Auto addressing and input the address of central control.
Jun 06, 2015 | LG Heating & Cooling
I got a C9 error on a C12AWR artcool split ac which doesn't work anymore i replaced the mainboard of the outdoor unit which didn't help i replaced the fan motor which didn't help either does...
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB. Multi V
= indoor PCB failure. Replace PCB.
Let me informed again if problem persists,.
Oct 25, 2011 | LG LA185HV Split System Air Conditioner
Split system air coditioners (3 off) LG LST243C-2, remote controls work intermittently or not at all after batt change. Reset does not help. Are they able to be rejuvenated (?) or is replacement only...
There is transmission problem. either with remote or in PCB. Check with mobile camera by pressing any button in your remote. If ultra light flashed in your remote, it's o.k. Then you have to repair/replace PCB only.
Jan 20, 2011 | Heating & Cooling
How do you reset the C2 fault code on a LG mini split unit?
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Jan 15, 2011 | Heating & Cooling
Lg split system ch 46 error? help!!!
Ch-46Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor
Jan 07, 2011 | LG Art Cool LA181CNW Split System Air...
Hi,mitsubishi ms12tn mini split ,when i put on the
There is small PCB in the AC, this PCB is malfuctioning also there is automatic ON /OFF switch Check whether ti is working properly or not.
Oct 02, 2009 | Mitsubishi MS12TN Air Conditioner
Split screen and dark colors
Good Day, scharania;
Try all of these: 1).HORIZONTAL PULLING AND TEARING, MAY ALSO HAVE VERTICAL ROLLING OR VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB. 2). CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. 3).
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. Good Luck, big IRISH.
Jul 30, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Heating & Cooling Logo
42 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
