Question about Vizio VX32LHDTV10A 32 in. LCD HDTV
Vx32l Power supply
When plugged in, the logo flashes white. Everything else is dead. Checked 5v, 12v, 24v outputs on power supply--only the 5v showed power. Larry
It is probably the capacitors on the power supply. Check them. I think there are 3 in a row. They are red in color and 450W. There is also a larger one next to them but I do not remember the volts.
Dec 04, 2010 | Vizio VX32L Television
Vizio VX32L TV will not power up?
Assuming the outlet is good, first place to check will be the pwoer supply module, chheck the main AC fuse, connections, etc.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Oct 25, 2010 | Vizio VX32L Television
Flat screen tv problem
42PF7320A: 7 blinks is missing 8.6VDC from supply -- connector CN-1M46, pin 3 (out of 11 pins), goes from power supply to main/input board.
Apr 21, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
I have a Vizio VX32L and when I turn it on the screen flashes and goes black. The power light comes on and the vizio sign lights up and turns white. But the screen flashes real fast and goes black again.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX32L+
Dec 16, 2009 | Vizio VX32L Television
Vizio vx32l
if you have audio but no video you do not have a power supply problem. make sure all the video supply cables are installed correctly and that you have signal coming into your input
Nov 02, 2009 | Sport & Outdoor - Others
TV BROKE
This sound comes from something short-circuit. Probaly, the cap exploded. Open the cover and see if the power supply has problem, you need to relpace it.
Aug 12, 2009 | Vizio VX32L Television
Vizio VX32L tv has red splotches all over the screen where dark areas are.
this site provides you with a simple program you can down load, I have used it myself on a lap top and a flat screen and it works the best. you may have to purchase it to run it for up to 48 hours, but it saved me 300 in repairs or new monitors
Jul 12, 2009 | Vizio VX32L Television
Vizio VX32LHDTV10A 32 in. LCD HDTV Logo
22 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
