Electrolux EWF1090 front loader - what does error message E70 mean, thanks
What does the error message E70 mean, it is not in the instruction booklet, thanks
aborcass
  • 2651 Answers
SOURCE: E70 error on Model LTF2940FE1 Front loading washer
good to see you cked that , 1 question though are you by chance using stainless hoses made by company FLOODSAFE. if so theres your problem theres a shut off inside the hose itself that is malfunfuctioning, replace with regular s/s hose and all will be good. if your not usinf a floodsafe hose hten lets go to the next hting- when oyu first start machine, cold water flows in before cycle even starts, can you hear it coming in??? at least trying perhaps a light humm with no water? water vavle is located under main top you can remove the top and check for voltage when trying to fill
Posted on Mar 10, 2008
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
SOURCE: I have a Fridgidaire Front
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Posted on Dec 03, 2008
  • 686 Answers
SOURCE: Coin stuck in front loader washer
GO TO www.repairclinic.com IN THE BRANDS WINDOW CLICK ELECTROLUX THEN IN APPLIANCE TYPE CLICK WASHING MACHINE AND LOOK FOR PART 1154917 CLICK ON THAT PHOTO AND LOOK AT ADDITIONAL PICS.YOU WILL SEE THAT IT SNAPS INTO PLACE. FROM HERE I THINK YOU CAN TAKE IT OUT AND RETIEVE YOUR COIN. GOOD LUCK
Posted on Apr 24, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
Belt snapped ..motor shaft turns freely
could be bearings or a brake for the drum energized
Call in a technician and get a repair quote
Jan 10, 2016 | Electrolux Washing Machines
Error code E40 on a Electrolux Front Loader Washing Machine EWF1090 What does it mean and how can I fix it?
Family error code E40 is visible to customers and (could be E41,E42,E43,E44 and E45 only visible in service mode) means problem with open door or door interlock.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and any of the option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the alarm.
The alarm sequence continues as long as the two buttons are held down.
E41 - Door open
E42 - Problems of door closure
E43 - Interlock power supply triac faulty
E44 - Door interlock sensor faulty
E45 - Door interlock sensing circuit triac faulty
Possible causes:
Door interlock faulty, wiring faulty or PCB faulty.
Dado
Feb 24, 2015 | Electrolux Washing Machines
I have a Electrolux front loader and im getting an error code of e35 what does this mean
Signals washer has overfilled, pressure hose or pressure switch most likely
Dec 25, 2014 | Electrolux Washing Machines
What is error code E41
Hello Scott - If you are receiving an error code E41, your loading door may be ajar. Double-check to ensure that it is closed. If it is secure, reset the power to your appliance for about 30 seconds. You can do this by unplugging the unit or flipping your circuit breaker into the off position. If the error persists, it could either be the door switch assembly or your unit's main control board. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Jun 10, 2013 | Electrolux Ewf1090 Front Loader Belt Part...
E70 error code on electrolux dryers inspire, it is working but dries the clothes to damp then this code comes up
Hi Nora King - Error code E70, typically means that there is a communication error with the outlet/inlet control thermistor that has an open or short circuit. You will need a certified professional to check the resistance of outlet/inlet control thermistor and check wiring for either short or open circuit.
Sep 17, 2012 | Electrolux Dryers
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Electrolux front loader.EWF1090 i have the replacement belt but am having trouble fitting it. belt seems too tight. is same as the roken one. any suggestions?
put it on the small pulley first, then hold it on the large pulley with your hand and slowly turn the big drum, ensuring the belt stays on the big pulley as you move it. line up where you place the belt on the small motor pulley with the drum or it may slip off again.
Dec 23, 2009 | Electrolux Washing Machines
E70
HI, this is a major control board fault code. the chip set on this board is damaged. it cannot be repair and, it is recommended to replace the entire control board(main) in this case.
A service call is recommended.
Jun 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
