Question about Dell Inspiron 2200 Notebook
No sound from computer
The sound on my computer just recently gave out on me for seemingly no reason. When it stopped working, I checked the volume bars to make sure nothing was muted, I restarted the computer, I installed the only sound driver update that was available for the computer and I even did a system restore to a previous date, but none of that worked.
I think that the sound card may have died on me, and I was wondering if there was anything else I could do that may help the problem.
I was also curious about something I heard. I was told that the sound card was part of an integrated system that also included the computers video card and the motherboard and that getting the sound fixed meant I would also have to get the whole motherboard replaced. Is that true for this laptop?
  • Threesix Oct 27, 2008
    No flags or alerts come up in the device manager, and after doing a diagnostic it says that the Analog Sound Playback and the Record Playback features aren't working.
  • Dell Master
  • 998 Answers
Yes that’s true. The sound circuit is integrated into the motherboard. Does your “Device Manager” have any yellow or red alerts or flags next to the sound device? To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column (Windows XP). If there are no errors displayed, run the diagnostics on the laptop. Press and hold the <Fn> key while powering the system on.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Oct 27, 2008
  • Walter H Boehm Oct 27, 2008
    I’m afraid that the motherboard has a problem. If the laptop is under warranty Dell will replace the motherboard.
    Thank You.
Mackie srm 350v2 speaker packed up
I believe there is an internal fuse in these which, according to a friend who has these, seems to blow occasionally for no apparent reason. He has also had to send two back for replacement and would not buy again, they seem to be inherently unreliable although they sound great.
Jan 02, 2013 | Mackie SRM350V2 POWERED SPEAKER
There are a total of 4 users on my computer. I am the administator and for reasons unknown the sound has stop working on mine. I am running windows xp7. How can i restore my sound? Thanks!
seems odd 4 users all getting sound but you're not on same computer !
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 15, 2011 | Computers & Internet
Installed every driver for sound from HP webite, still no sound. It has integrated audio (Soundmax) and has always worked fine but recently stopped. I checked for viruses, repaired registry also....
The integrated audio could be defective in your motherboard. Another reason is that your computer is trying to use old devices or devices your installed on your computer that are not compatible. Click on your volume icon (right click) and go to playback devices. Make sure the correct device is selected.
May 12, 2011 | Computers & Internet
Hi, I have a Samsung SyncMaster215tw, I've been using speakers to hear music and movies but recently gave them away, how can i get sound directly from the monitor?
The manual (you can download it here if you need a copy) shows an audio input jack right next to the VGA input connector. This jack takes a 1/8-inch stereo plug the same as the output jack on the computer. You can use the same cable that is usually supplied with computer speakers. Just plug the cable into the computer's sound output jack and the monitor input. I'd recommend setting the volume on the computer to maximum, and using the monitor volume control to adjust your sound.
Apr 01, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
Dell computer seems to have lost it's external sound
This could happen for several reasons. Of course, the first is that the speakers might have gone bad, but that is not usually the case.
The next reason would be if you have muted the speakers in the "sounds" option in the control panel. Check that. While there, be sure you have the volume up and not way down.
Jan 05, 2010 | Dell Inspiron 1525 Laptop
No sound. I have owned the speaker system for over 10 years. The speakers had been working fine until after I disconnected them to travel with in my car trunk, then reconnect to my desktop computer, also...
Try changing the fuse. It's located below the power cord. A friend gave me the set I now have because they had stopped working. Turned out the fuse had blown.
Dec 17, 2009 | Altec Lansing ACS 495 Computer Speakers
Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
MS-900 (AOpen speakers)
please install motherboard cd in you pc then set the volume control option to windows default thats all..your speakers will get ready to work properly...
Dec 30, 2007 | AOpen MS-900 Computer Speakers
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Check the sound card system Can your hear through headphones for example?
Nov 15, 2006 | Logitech X-230 Computer Speakers
Dell Inspiron 2200 Notebook Logo
Alun Cox
