Question about Campbell Hausfeld 5HP 20 Gallon Single Stage Cast Iron Air Compressor VS5006
Can't find reed valve replacements for 1999 campbell hausfeld?
Campbell Hausfeld Model # C107108VMSA ... Does anyone know where I can find a set of replacement reed valves for this unit? And maybe a few other things too without having to sell my soul (sorry, a bit frustrated)? The pump # is C1070000PB ... I've tried these model #s at every internet store I can find, and it is like they do not exist. This unit was manufactured in 5/3/99. Thanks!
  • Don Fuller
    Don Fuller Feb 22, 2012
    Repair Man -- Thank you for trying. This air compressor is not portable, but is quite large, verticle 8 HP, produces 27.2 ave SCFM @ 90 PSI. I hope you'll take another shot at it. the mod # for the whole unit is C107108VMSA; Ser # L 5/3/99-00073
    The stated mod # for the pump is C1070000PB.
    Thank you!
The pump number is C"i"070000PB not C"1"070000PB. If you google Ci07000PB you will find tons of parts.
Posted on Dec 03, 2013
  • Campbell Hau... Master
  • 885 Answers
I am a C-H service center and using the model number VS5006 I got the following:
- Your Pump Part Number was originally VS260000KB, now it's VS260000SJ. That's the complete pump and suggested retail is $199.99.
- The valve kit for that pump is part number VS261000AJ. The kit includes all the gaskets, reed valves and valve plates between the head and cylinder, suggested retail is $33.80.
You can go to http://www.ereplacementparts.com/ and, using the model number VS5006, see a breakdown of your compressor or, using VS260000SJ, see a breakdown of the pump to make sure we're talking about the same air compressor and pump. The parts are available through them or you can use the part numbers to search other sites for better prices.
Posted on Feb 21, 2012
4 Suggested Answers
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
roniecon
  • 6826 Answers
SOURCE: campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Posted on Oct 05, 2009
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
Posted on Feb 01, 2010
Product - Campbell Hausfeld TL1017 Butterfly Impact wrench I need a set of plastic valves. Where can these be purchased?
1-800-444-3353. This number is in the manual should you need some technical advice. I'd give them a call and see if they will mail you what you need. Can't find you a rebuild kit out on the net.
Sep 18, 2011 | Campbell Hausfeld TL1017 3/8" Butterfly...
Campbell Hausfeld 13 gal air copressor, when I trun it on it won't build up max pressure and won't shut-off One of the gauges reads 40 PSI the other reads 60 PSI.
Your problem is most likely because of damage to the valve plate or piston & cylinder. If one or both of these are not working properly you'll get partial pressure and the unit won't turn off because the tank never comes up to full pressure. Things to check for are damage to the reeds on the valve plate, they could be bent from overheating or broken from use or wear or damage to the piston seal which can cause damage to the cylinder. If any of these aren't sealing properly the air pressure will come up to a point where the air leaks out faster than it goes into the tank. Without your particular model number I don't know which parts to recommend but if you contact Campbell Hausfeld they'll help you get the right parts.
May 12, 2011 | Campbell Hausfeld 13 - Gallon Air...
My compressor charges up to 60 PSI. It keeps on running but will not charge over 60PSI. I feel or see no leaks. Why?
Reed Valves in cylinder head. Pull head off and order Valve Kit through Campbell Hausfeld. Phone number etc is on internet.
Apr 27, 2010 | Campbell Hausfeld 26 - Gallon Air...
Campbell Hausfeld 5HP 20 Gallon Single Stage Cast Iron Air Compressor  VS5006 Logo
257 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
