Question about Tally T8106 Laser Printer
Tally T8106 Does anyone know, if the Tally T8106 can be used with Vista and XP over an ethernet conncetions and how? I operating systems don't seem to find the printer on the net. Any suggestions ???
    Novelist:
  • 169 Answers
The T816 can be used with Vista and XP over a Ethernet connection....You will not however be able to 'discover' the printer on the network.You need to set an IP Address in the printer or if the printer has been allocated a DHCP address you would need to find out what address has been allocated.
Once you know the IP Address you would need to install the printer on a PC/Server then share it to other users to be able to 'see the pritner on the network'
Once the pritner driver has been installed you can create a network port in the pritner driver to print to the IP Address of the pritner in the follwing way (on XP, Vista will be simmilar)
· Open PRINTERS folder
· Right Click on the printer driver for the T8106
· Select PROPERTIES from pop up menu
· Click on the PORTS tab
· Click on the ADD PORT button
· Highlight STANDARD TCP/IP PORT
· Click on NEW PORT
· This should open the TCP/IP Printer Port Wizard, work through this entering the IP Address and Port Name. Windows may try to detect the port configuration required.
· If the type of port is not automatically detected click on the CUSTOM radio button.
· Click on the SETTINGS button
· Change the PROTOCOL to LPR
· Under LRP SETTINGS enter the Queue Name as PASS
· Click OK.
· Click NEXT and then FINISH to finish the TCP/IP ports wizard.
Posted on Sep 18, 2009
I have just unistalled vista and replaced it with windows xp pro but driver for ethernet controller are not installed my computer is iqon
If you are doing this on a laptop then that's probably because there was no driver ever made for your ethernet controller for Windows XP pro. This is a standard tactic that Microsoft and the computer manufacturers use to get you to upgrade your operating system and never go back to an older operating system.
It means less headaches for manufacturer since they then don't have to go back and make an extra driver for an older operating system which saves them time and money and of course Microsoft gets money for every operating system purchased with a new computer.
The good news is there is an easy solution. You can buy a small USB wireless ethernet adapter to plug into one of your USB ports and you will have internet again. It will come with a driver disk, but many times your operating system will automatically install the correct drivers when you plug the device in.
You can get a great deal on a new USB wireless ethernet adapter here:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100010074%20600014288&IsNodeId=1&name=USB%202.0&Order=PRICE
I particularly like this model because it works well and is very small:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833315091
May 29, 2012 | Microsoft Windows XP Professional With...
I forgot my password and i dont know how to reset my toshiba satellite l25
Don't worry about it , I know the easy way to recover windows password, you can use the software called Smartkey Windows Password Recovery which is easy and effective to operate, and you can download and seethe using method from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
It can support Windows 8, 7,Windows XP, XP+SP2, XP+SP3, 2000, 2003, 2008, NT, Windows XP Professional x64Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems,Windows VISTA, Windows VISTA(64-bit).I hope it can work out for you.
May 09, 2012 | Toshiba Computers & Internet
Can 1gb ram supports tally software with atom processor
System Requirements
  • Recommended Hardware Requirements for Tally 9
  • Pentium 4 and above or equivalent
  • 256 MB RAM
  • Minimum Disk Space: 40 MB
  • Operating System Software: Microsoft Windows 98/ME/NT/2000/XP
Hence, your system would definately support Tally.
Hope it helps! Good Luck!
CreativeTECH
Mar 19, 2011 | Samsung Netbook / Intel Atom Processor /...
I forget tally vault pasword
if your operating system is windows xp try to press ctrl-alt-delete then type the user name "Administrator" then login, then go to control panel and click user acount and then remove the password...... for windows vista and windows 7 you should reinstall the operating system so that you can use again your computer
Nov 18, 2010 | Computers & Internet
Unable to get any Internet access with IE7, IE8, Firefox etc...
XP or Vista ?
Go to Network - Properties - the network card. Make sure you have "Get network address automatically"
DOS box type ipconfig /all what's it say.
There are viruses that can kill TCP/IP
Get a copy of LSPfix It will check your TCP/IP programs.
I did have one XP machine that lost it's network setting, could never get it running without a reinstall.
If Linyx works, it's not the card.
Jul 27, 2009 | Compaq Computers & Internet
Y does tally7.2 aint workin in vista
Try installing it in compatibility mode of XP SP2
Tally 9.0 works without any issues on Vista
Jun 26, 2009 | Microsoft Windows Vista Home Basic Edition...
Replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
May 28, 2009 | Tally T8106 Laser Printer
Can we download the Windows Vista theme on Windows?
Of course you can. They are named as Vista Inspirat 1, 2, 2.1, 2.2 and more. This is a crystalnet product........sodeep
May 17, 2009 | Microsoft Windows Vista Ultimate Edition
Ethernet driver not installing
i have been serching around and it seems compaq.hp does not supply a eternet driver for xp unless you aretalking about the wifi card drivers it seems xp is supposed to have the drivers with it. i do not know what you meen by "how will i get vista on net?" i will keep looking for a sulution
Sep 26, 2008 | Microsoft Windows Vista Ultimate Edition
VISTA VS XP
Here they are: http://tinyurl.com/3a6lrb M
Aug 28, 2007 | Samsung Q1 Tablet PC
Tally T8106 Laser Printer Logo
116 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
