Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator Seperation Thanks for the advise. I have tried pulling very hard, to the point where the lower half plasitc is stressing, without sucess. The cam-agit appears to have four white plastic attachment pins going thru it. But I have not found a way to release (depress, bend, etc...) them. Two of the four also appear to be damaged. Can the pins be my separation problem???
    Novelist:
    Champion:
  • 261 Answers
The upper and lower halves should be joined as such. There is a 7/16 bolt in the middle that should be loosened to help removal. If not get and old belt and place it under the agitator and carefully pull up to help release it. Here is a schematic and list of parts.
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=LSQ9549LQ0&productCategoryId=0153200&brandId=1198&modelName=WASHER - DIRECT DRIVE&diagramPageId=00003&componentDescription=AGITATOR, BASKET AND TUB&documentId=W0207069&backToLink=Return to Sub Components list
Posted on Nov 01, 2008
  • John Robbins
    John Robbins Nov 07, 2008
    Easier to order a new agitator as the design is a little different.
Need to remove the tub on Kenmore Series 60 Washer to clean it. How do I get the agitator out?
To replace the Agitator & Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa!!
Aug 04, 2011 | Washing Machines
Trying to remove the agitator from a kenmore top loader. took off agitator cap but there is no nut down inside. i see metal but nut drivers and sockets won't fit, down opening. should i just pull up on the...
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
Oct 10, 2010 | Kenmore 24972 Top Load Washer
The agitator tries to rotate, but instead jerks, but doesn't rotate in normal motion. It also makes a ratcheting snapping sound.
Does the lower half of the agitator still operate normally? (Back and forth) Can you spin the top half (spiraled part) of the agitator in both directions with out the lower half moving? If so then you have a worn set of agitator "dogs" they are little plastic ears located in the upper half of the agitator and catch the notched inner section of the agitator to make the top action work like a corkscrew, slipping one way and driving the other as the lower half goes back and forth.
To get at these parts you will need to remove the agitator, Remove fabric softener dispenser or cap on top, and look down inside tho opening.
You will need to remove the plastic cover inside that has two ears sticking up, pull on one side or the other and it should pop out, there will be a rubber seal around it so it will be a little difficult to remove.
Now you will have access to the bolt that holds the entire agitator in the machine. The agitator dogs are located right on the outer edge of the center cup that the bolt goes through. To access them you will want to seperate the two halves of the agitator and flip the top half upside down while holding your hand inside it to catch the cup with the dogs in it. Part number 80040, for the dogs.
Good luck to You!!
Jun 26, 2010 | Roper RAS8445KQ Top Load Washer
Agitator free spins, will not engage, sounds like a gear is stripped. How do I remove agitator
At the top of the agitator there is a seperation of the agitator and the very top of the agitator. If you hold the fins of the agitator and attempt to unscrew the very top of the agitator this should come loose allowing you access to pull the rest of the agitator out
Hope this helped
Dave
Feb 23, 2010 | Washing Machines
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator top to bottom rotation seperation
387091 is the part called agitator clutch or dogs,they are little yellow pieces of plastic with teeth on the ends to grip the agitator and turn in it the teeth are worn off of yours..
Sep 02, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
How do I replace the dogs in a Kenmore Elite washer?
With a flat blade screwdriver or putty knife, remove the top cover from the agitator. Use pliers to pull out the inside plastic cover.Take a 7/16 socket on a extension and remove the nut .Pull the agitator out. It should separate. If it does not separate,stand on the lower half and forcefully pull up on the upper half.Remove the agitator dogs and spline gear from the upper agitator. Replace the dogs. Re-assemble the agitator. Wash clothes.
Jul 14, 2009 | Kenmore 15.5 in. Pedestal
Washing machine agitation problem?
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 14, 2009 | Kenmore Washing Machines
Dual Agitator not working
If the upper portion of the agitator is not working, this is commonly caused by worn agitator dogs. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Yes...there is such a thing. These small plastic pieces have been the source of many trouble calls and only cost a few dollars to replace if you know how to do it. Replacements can be ordered on line at searspartsdirect.com, appliancepartspros.com, or repairclinic.com. Use your model number for the search criteria and look under the "Agitator Parts" section. The link also give instructions on how to remove the agitator. This is a very simple repair, that only costs a few dollars. If you wish not to order on
line, use the part number provided by the Sears website and go to your nearest appliance parts retailer. This is a common part they will have in their inventory. If you require further assistance, please let me know. I hope this helps you.
Jan 09, 2009 | Kenmore 24032\24036 Top Load Washer
Broken Washing Machine Agitator
probably just what is known as agitator dogs just worn ..with no brand or model i assume it's a whirpool or kenmore ..1st remove softner dispenser (without brand can't say how it would come off ..some twist off some just pull off ) if agitator has cap underneath pull it off in center of agitator should be a bolt 7/16 if kenmore/whirlpool..remove it pull up on top half ..whole thing may come out if so just pull up sharply on top part..center part of top half comes out dogs are on it( 4 )again i'm assuming kenmore/whirlpool whirpool part # 80040 replace them and reassemble ..if any other brand will probably have to replace entire agitator..good luck
Sep 11, 2008 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
