Question about GE 46GW 948 46" Rear Projection Television
GE 46GW948 shuts off when cold then works fine
HI my GE built in July 2000 Model 46GW948 is havine a problem just started.
When first turned on after being off for a few hours it works alright and then the screens distorts(sometimes) and then goes black and no sound except maybe a little hiss or crackle, then comes back on,sometimes it actually powers off and must be turned back on. It may let you watch 5 minutes or 5 seconds or maybe even ten minutes at a time. It does this off and on for about hour or so and then works fine. Any help would be much appreciated
  • roadfire Oct 27, 2008
    Yes I can solder. This is my first repair on this type of equipment, I have solder many wires into connectors and on a board a few years ago, so I should be able to do this, a question I have is this how many convergence ICs should there be I only see one and don't want to disassemble any farther than necessary to avoid any problems that could cause. The one I see is on a single board with very easy access. Thank you
  • 4,234 Answers
This is a classis symptom of poor solder connections that when heated connect well. If you can solder, you should be able to fix this yourself. Resolder any connections that appear to be grainy or have rings. Note: The most likely location of these poor connections are at the convergence ICs. These are large black ICs attached to a heatsink and should be marked STKxxx. There are high voltages floating around inside these sets even when unplugged, so be careful.
Keep me posted.
Dan
Posted on Oct 27, 2008
GE 46GW948 TV Sound turns up by itself. Checked button looks fine
What happened on a lot of these is the micro switches on the front go bad.
With back off (set unplugged) located the bundle of wires coming from front keyboard to top of set(a small pc board near the top of the middle of the three tubes).
Unplug the plug going to the keyboard----set will still work as remote receiver is also on that board.
Questions?
Steve
Feb 28, 2012 | GE 46GW947 46" Rear Projection Television
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
GE Refrigerator-Freezer side works fine/Refrigerator side not ok
You most likely have a defrost problem. Check the inside back panel of the freezer. See if there is ice built up. If so, you have a problem with the defrost. 85% of the time, it's caused by a bad heater. It could be the termination thermostat, timer or fan. If the ice is built up. Take the panel out and defrost with hair dryer. If you want, you can now check the heater and termination thermostat. It's a closed switch that opens on the rise. If you fix it your self or not, To save your food. You can replace the panel and turn the fridge back on, it will operate correctly for 3 or 4 days. This will give you time to either get the part and fix it or for someone to get out and repair.
Please rate solution and make it worth the while to summit solutions. Thanks
Aug 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
May 17, 2009 | GE Microwave Ovens
GE Model # GSS20IEPA WW Fridge warm...freezer is fine
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,
Mar 28, 2009 | GE GSS20IEP Side by Side Refrigerator
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Gemstar 46" model 46GW948
can you hear the starting or a noise from the back?try unplugging then put back.sound to me that you will need a tech
most probably the trippler going bad.
Jose
Aug 09, 2008 | GE 46GW 948 46" Rear Projection Television
Will not turn on
That model is notorious for bad power/ deflection boards and flyback issuses on that same board
May 20, 2008 | Televison & Video
Cracked screen
I think that Thomson is the manufacturer or distributor for GE parts, and Global INC is one of their distributers. keep that it mind when looking for your screen. and you might be able to get it at vancebaldwin.com good luck
Mar 16, 2006 | GE 46GW 948 46" Rear Projection Television
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
113 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
