Question about Air Tools & Compressors
Repair manual for quincy model 310 compressor
3 Suggested Answers
compman66
  • 169 Answers
SOURCE: when the comp. shuts off the air bleeds back out
You have one or more valves broken in the head and need to be replaced, and Quincy compressors require a special tool to remove and install valves.
Posted on May 08, 2010
  • 54 Answers
SOURCE: What kind of Oil would
30W Non-Detergent. You can get it at hardware stores or tool stores. You can go with synthetic if you like, but if you don't run it too hard, regular oil is fine.
Posted on May 28, 2011
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Whyintake unloader valve does not close when starting comp. only i have closed the littel hole with finger pressure?
dirt in valve or bad diafram on unloader activator most likely both reasons you'll find are true
Sep 16, 2014 | Air Tools & Compressors
Air Compressor
No that is not the oil filter. The oil filter # is 110814-001 comes 6 to a pack.
Apr 11, 2014 | Quincy Compressor 110382D075 0.75 NPT...
How does the the air unloader assembly for moded 310 come apart
Should just have to unscrew it without taking head off. Use a big wrench to fit the big part of the unloader.
Feb 03, 2014 | Quincy Compressor Air Tools & Compressors
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
When the comp. shuts off the air bleeds back out the intake. what needs done to stop this It is a quincy model 350 2 stage compressor
Apr 29, 2010 | Air Tools & Compressors
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
666 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
