Question about Whirlpool GEW9200L Electric Dryer
Whirlpool Duet Dryer is scorching clothes
Our Whirlpool Duet Dryer Model # GEW9250PW1 is scorching clothes. The heat seems to be very hot even when set on low heat. Our clothes have burned marks on them. Any ideas?
  • 6 more comments
  • tempestausmc Oct 29, 2008
    On the parts diagram there is a thermostat near the heating element. Is that the same as the sensor?
    Thanks
  • Anonymous Dec 18, 2008
    I have a similar problem with a GE gas dryer. I'm thinking it's caused by dustballs/spiders getting sucked into the burner, then the flaming dustball/spider is being extinguished by my white shirts/towels.
  • Anonymous Mar 13, 2014
    Wet clothes sensor comes on when you push the start button but dryer won't start
  • Anonymous Mar 15, 2014
    the dryer has no heat and tried everything to fix it
  • Anonymous Mar 20, 2014
    Clothes do not UNWRINKLE, come right out of the dryer wrinkled also.
  • Anonymous Mar 21, 2014
    makes noise whin turning
  • Anonymous Mar 22, 2014
    And dryer heats up
  • Anonymous Mar 28, 2014
    my dryer is leaving scorch marks on my clothes. What could be causing this?
  • 67 Answers
There is a sensor in the exhaust line in the dryer, near the motor. this tells the heating element to shut off when it gets to a certain temp, either during reg cycle or if the exhaust gets clogged, it is meant as a safety measure, but it sounds like yours is bad so the heating element never shuts off. it is not an expensive part and easy to replace
Posted on Oct 28, 2008
  • knvosss Oct 29, 2008
    no, it is not. one way to tell which one is bad might be to check the temp in your duct. check it as close as possible to the dryer itself, the temp should be around 130F. another thing to check is if the heating element is turning off at all. you can check this by removing the bottom panel from the front of the dryer and looking in as the dryer is running. you should be able to see the element when it is on (it looks like a toaster) put your dryer on low heat (or maybe even no heat) and see if it turns on. under normal circumstances, it should cycle on and off. if the sensor is bad, it will just stay on. i have never had any experience with the thermostat, but if the sensor is working, it should shut it down when it gets to a certain temp. the sensor is cheap i think so it might not be a bad idea to replace them both
REPLACED SoLeNOID COILS AND IT BURNS BUT SEEMS TO BE A LOW FLAME
How to fix a none heating Whirlpool or Kenmore gas dryer ...
www.askgene.com/...dryer/...dryer/how-to-fix-a-none-heating-whirlpool...
Dec 27, 2006 - How to find, test and/or replace the igniter, the radiant flame sensor ...The part number for the Whirlpool gas valve coils is 279834. ... The main coil seems to be energized all the time and the auxiliary coil is ..... I have a whirlpool gas dryer model WDG5600SQ0 ,the gas will ignite into a flame but burns out ...
Clothes Dryer Troubleshooting ' Dryer Repair Manual
Jan 01, 2016 | Dryers
I have a whirlpool duet model gew9250pw1 dryer it gets good and hot put when the cycle is done some of the clothes are still damp.i not sure if it is the timer or a censer. i know when we start it the...
Look for an airflow blockage. Be sure lint filter is cleaned and if lint is accumulated in the air stream path, take a vacuum or brush and clean it out. Dirt and lint are a dryer's worst enemy.
Mar 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
I have a Whirlpool Duet model GEW9250PW1. The unit has heat, but not hot enough even set on high and takes very long to dry. I have checked all the vents and they are clean and clear. The temp...
check the end of the vent outside of the house if the air comes out with full force if yes try to take continuty on the high limit thermostat
Sep 05, 2011 | Washing Machines
I have a Whirlpool electric dryer, it is a Duet with a model # of: GEW9250PW1. When I try to select the the "normal" setting on the automatic side, it lights up the delicate light and has the...
Is the selector knob loose on the stem? Look on the knob to see if there is a set screw of some sort that you can tighten to set it where it belongs, it just seems it's loose and isn't pointing to where it should. Let me know if this works or not,
Please rate and comment, Thank you,
Joe
Sep 01, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet dryer is making a high pitched screeching noise. Model gew9250pw1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 10, 2011 | Whirlpool Dryers
I have a whirlpool duet # gew9250pw1 it won't
my whirlpool dryer has power but does not start
Jul 02, 2011 | Whirlpool Dryers
Whirlpool duet dryer, dryer gets to hot, even on delicate cycle, clothes to hot to touch
may be the heat sensor(around 10Kohm) or the heater relay on the control stuck in the on position.(new control)
Oct 29, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
1,202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
