Question about Whirlpool Washing Machines
My washer will not agitate or drain. but it makes a hummimg noise. can you give me an idea as to what the problem could be?
  • 1 more comment
  • kristhack Oct 27, 2008
    Does the humming noise mean that the motor is running?
    if the belt broke wouldn't i have smelled something burning?
    Thank you! I will try that out. I really appreciate it. Have a good day, Kristin
  • Whirlpool Master
  • 19,396 Answers
Check the following:
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
From repairclinic.
Posted on Oct 27, 2008
  • Ginko
    Ginko Oct 27, 2008
    If you hear humming noise, like the motor is running, but it does not spin, then it may be the belt.
  • Ginko
    Ginko Oct 27, 2008
    The belt can have simply slipped out, in this case the machine won't spin at all.
    There is also an electronic control module that controls motor, and in some model a clutch.
    The first thing to inspect is always the belt, if it is not in tenstion there will be spinning problems, and if it slipped out, the machine won't spin at all.
    Here you get diagrams and parts, insert the model number.
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
I have a wcsr2070t2ww (GE) that will not agitate. it will spin, drain, and make noise during agitation cycle but no movement. any ideas?
The belt is definitely broken. to get to it you will need to remove the top of the machine to remove also the front panel.
Oct 28, 2009 | GE WBSE2090A Top Load Washer
Sears Kenmore 80 series will not rinse or drain
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine won't agitate, spin, or drain
It sounds like the motor needs to be replaced, you can drain the water by taking the drain hose from the drain and lowering down water will drain.
Jun 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
The problem sounds like the motor to transmission coupler. If it is not draining or spinning you may find that the lid switch is inop.
Dec 07, 2007 | Washing Machines
Washing Machines Logo
119 people viewed this question
Dan Webster
Dan Webster
Sal De
