Question about Whirlpool Duet GHW9150P Front Load Washer
GHW9100LQ1 machine stuck in control lock mode
I know there must be a simple solution... how do I escape from the control lock setting? Stuck in Control Lock Mode
  • judyaboo Oct 27, 2008
    jsrock516 You really do rock! Thank you.
    Super, it worked. Had not noticed that little button, now one more problem.
    My ex was using the machine when this happened and now I cannot close the door. I try to use pause/open door and that does not work, ust turns off the control panel. I can't reach the plug to unplug it for a while as suggested. He said he did not jimmy it open. I am afraid to force it as I might really break it more. Any suggestions?
  • etniacrazyla Oct 28, 2008
  • 5,911 Answers
Press and hold the "END OF CYCLE SIGNAL" button for three seconds and it will unlock the control panel. At least, I think that is the button for the Whirlpool Duet. If you look closely at the front panel, it will clearly state "Press and Hold for 3 Seconds to Lock" on one of the panel buttons (should be all the way to the RIGHT HAND SIDE). This button is designed as a safety feature to prevent small children from being able to operate the washer and inadverntenty getting locked inside the unit. If holding the button fails, unplug the washer for at least 30 minutes to reset the computer. I hope this helps.
Posted on Oct 27, 2008
  • Jeff Rockwell
    Jeff Rockwell Oct 27, 2008
    Well, if you can't reach the plug, find the circuit breaker at the service and turn it off for at least 30 minutes. In many cases, this is all that is required to clear momentary computer glitches. Another method involves removing the lower panel under the door and using the manual release to open the door. The following link explains:
    http://www.fixya.com/support/r622155-ken...
    Hopefully, you will find the breaker and that will correct your problem. If not, you have the secondary method in the link provided. I hope this helps you.
  • Jeff Rockwell
    Jeff Rockwell Oct 28, 2008
    "Thanks for Trying?" Could you please provide some feedback as to why the adverse rating? You rated the solution, but fail to offer reasons, or give me feedback in order to try to assist you better.
Anyone know why
If the machine has a mechanical control, the timer is stuck in a certain position. Whatever cycle it is stuck on will continue to run until the timer is advanced to the next setting. If you have an electronic board controlling things then that board is defective and needs to be replaced.
U might try unplugging unit to see if that affects the electronics. If manual timer, unplug unit and move the cam yourself to the next position.
Aug 06, 2015 | Maytag Washing Machines
Washer is stuck in "control locked mode" and won't start. It's normally in door locked mode. Whirlpool duet
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. .
Jul 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Stuck in safe mode. error code 01. please help
This is what is called a mem lock-up and to escape you need to press reset, though you will need to set up the clock etc again.
Jun 15, 2010 | JVC GR-D270 Mini DV Digital Camcorder
My washer control is stuck control lock
The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When washer was off it filled up with water and overflowed will a water inlet valve fix this. this is a whilpool washer frontload ghw9100lq1
Yes, it should. The only way water can enter a washer when off, is through a stuck inlet valve, or by siphoning water from a drain hose installed too deeply in the stand pipe. If your machine had enough water coming in to overflow, that definitely sounds like a bad inlet valve.
Apr 21, 2009 | Whirlpool Washing Machines
Compaq laptop with Vista is stuck on hibernating.
When it finally shuts down, and reboot, does it comeback to windows?
let me know
Apr 10, 2009 | HP Compaq nc6000 Notebook
sure is,look to the far right buttons one says hold to lock/unlock the controls. hold it for 3 secs and your good!
Oct 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
GO-Video model DVR440 (DVD/VCR combo) Child Lock ON, No response to POWER button
can only be done by remote control unless you have the complete manual to reset all your saved settings from the front panel
Mar 31, 2008 | Televison & Video
GO Video ? DVR440 (VCR/DVD) Combo
The only other thing I can think of is to unplug the machine for 5 minutes and see if the machine defaults to the factory settings...accordianman
Mar 29, 2008 | Televison & Video
Whirlpool Duet GHW9150P Front Load Washer Logo
348 people viewed this question
Dan Webster
Dan Webster
Sal De
