Question about Sennheiser SK 300 G2 Wireless Bodypack Transmitter Microphone
Low Battery Indicator
My bodypack transmitter continues to indicate low batter even though the battery is new.
  • 6 more comments
  • Kwickwire Oct 31, 2008
    When I press the power button the LED says Lo 8AE and as soon as I release the on/off button, the message disappears. As of last Sunday, I could actually turn it on and it said LO BAT and the on/low batt light on the front flashed.
    BTW, this is actually an SK100 Bodypack transmitter but that selection wasn't available.
  • rshoffner Nov 03, 2008
    I have a SK 100 also and that problem just poped up. I used it with no problem Thurs. night and turned it off . then went to perform Sun. morn and all I got was the red on/low Batt light. I tried several new alkaline batteries and one the rechargeable we use in our wireless handhelds. Any ideas why?
  • Kwickwire Nov 03, 2008
    We use 9 Volt Duracell Procels which, I understand, are designed for this application.
  • rshoffner Nov 06, 2008
    problem Thurs. night and turned it off . Then went to perform Sun. morn
    and all I got was the red on/low Batt light and it won't turn on. I see nothing on the screen when I press the red power button. I tried several new
  • Kwickwire Nov 10, 2008
    I'm still waiting for some help with this problem. Any ideas?
  • mkferrari Mar 05, 2009
    ew 100 bodypack transmitter. Worked fine one night...normal shutdown...then low batt with same good battery and new battery.
  • unicycle6869 Mar 10, 2009
    Anyone figure out a solution to the "low battery" warning even when they are brand new batteries?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi
    Can you give a little mire detail... what sort of indication does it giving you, what is the LED doing?
    regards
    robotek
  • 1,512 Answers
No worries, thanks for getting back to me. Another questions for you. What sort of batteries are you using. Are they rechargeable, alkaline, carbon zinc, or the Sennheiser BA 2015 accupack rechargeable.
Posted on Nov 01, 2008
How do I get my laptop to warn me that it is about to shutdown?
Your power management options should provide you with the option to warn at an appropriate power level.
Feb 24, 2015 | HP Compaq Presario CQ60-417DX
I have a sennheiser 300 iem g2 transmitter. Last night at a gig i was hearing some high pitched feedback through my in ears depending on where i was standing. Also the low battery light was on even wi
  1. "Feedback" might have been intermodulation with another RF frequency. Make sure to use Sennheiser's frequency finder, or something similar, to determine what TV channels are clear. If you're using more than one transmitter, make sure they're all using the same channel bank.
  2. The low bat/on indicator should be on solid if battery is good; and flashing if the battery is low.
Oct 05, 2014 | Audio Players & Recorders
Cobra Mirco Talk CXT 195
pls check usb cable , replace with new gud quality short length usb cable n try to connect the same in back side USB port not front side ..
Jan 15, 2014 | Cobra Radio Communications
I have the same problem. The ULX1 bodypack transmitter displays a RED battery light even when I use different batteries. I have used a voltmeter to test the batteries and they are good. I took the unit a...
I suggest sending the unit to Shure for repairs. The battery indicator is controlled by the micro. Thus, it needs to looked at by a service center that has access to the micro code.
Dec 07, 2010 | Shure ULX1 Body-Pack Transmitter...
Heart rate writst watch won't work
Here is the manual for your heart rate monitor:
http://www.omronhealthcare.com/img/shop/hr-100c---2003-hr100cinst-rev-a.pdf
The size of your wrist shouldn't matter, because you can actually mount the monitor to a bike handle, so you don't have to be wearing it at all. It's just acting as a receiver, displaying the info. Are you wearing the transmitter belt, is it positioned correctly, and tight enough? Are you putting water or gel on the backside of the transmitter so that you get good conduction and contact? Is the transmitter belt within 20 inches of the monitor receiver display?
The transmitter battery might be low. If so, the symptom would be that your readings can be erratic. I know you said that you just bought it, but batteries can be low in new products. ..How many times have you bought a new digital watch only to find that it had a low battery...You can replace the battery in the transmitter with a lithium 3v battery #CR2032. Do you see a low battery indicator? If so, the display (receiver) battery also needs replacing and it uses the same battery as the transmitter.
Hope it helps, please let me know.
Thanks
May 09, 2010 | Omron HR100C Heart Rate Monitor
TOSHIBA U400 running VISTA; When I am on battery and get low i plug in so i can continue working but even though the lighted icons on the laptop show it is plugged in and charging and the toolbar icons...
Yes it is, seems there is some problem with the power state detection and changing of the load mode. Might by a physical problem, so I am not sure you can fix it.
At least check your power plan details and see if there is any error with the ACPI devices in the device manager.
In general, if you use the laptop when plugged, you should take out the battery to maximize the battery life (prevents useless load cycles).
Also configure Windows to optimize battery usage.
Apr 24, 2010 | Toshiba Satellite Pro U400-S1001V Notebook
Low battery indicator, even after a new battery
You probably have a dead cell in your replacement battery. Camera batteries have a limited number of charge cycles, and this is not a rare issue with "aged" batteries. Also, when you get a new battery, buy a genuine Canon replacement and not one of the el-cheapo Chinese copies available online. In camera batteries, you really do get the quality and performance you pay for!
Jun 27, 2017 | Canon Photography
Canon eos rebel t2 battery indicator
guido462:
new batteries - brand new? fully charged per spec?
Jan 21, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Problem with battery,
Sounds like your battery isn't taking a charge so I would say your battery is the problem
Jun 19, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sennheiser SK 300 G2 Wireless Bodypack Transmitter Microphone Logo
399 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
