Question about Stihl Garden
Stihl 009 chainsaw replace throttle handle spring
How does the spring fit on the trigger
  • John Murphy Feb 21, 2012
    does the spring slip over the right hand lug and sit on top of the hook and the rest of the spring fits into the throttle trigger. Not sure if it explained very well but when I connect it this was it doesn't raise the hook lever outside the cover?
  • Stihl Master
  • 1,807 Answers
2 Suggested Answers
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Throttle return spring how to fit spring in throttle
remove carbi. remove throttle shaft .the spring is around shaft,.
Jul 15, 2014 | Stihl Garden
I can't get my stihl chainsaw trigger throttle and trigger interlock to catch so I can start it. I pressed them both at same time but does not catch.
Release the interlock button first, then the trigger throttle. If this does not work, replace the interlock button.
Oct 23, 2013 | Stihl 009l
Throttle down linkage
Open up handle and check for alignment on trigger and parts. You can look at an exploded view to see all the handle and trigger parts.
Sep 06, 2013 | Stihl MS181 14" Chainsaw
How do I reconnect ,my throttle trigger for ms 260
remove the top cover on the handle, there is a screw in the bottom of the handle end. put the on off switch in the choke position all the way down, connect rod to throttle on carburetor then slip it into the hole in the trigger. replace operator presence lever making sure the spring is in the notch on the side of it, while holding it in place reinstall the top cover.
Jun 13, 2012 | Stihl 024 026 Ms240 Ms260 Throttle Trigger
My 031 stihl chainsaw trigger is stuck in a full open postion, is it a spring or what
Expose the carburetor and try pulling lightly on the throttle cable--if it won't pull, the trigger assembly is probably full of sawdust. In that case, remove the handle cover over the trigger (record the position of all parts before trying to take anything apart to clean). You should be able to see any blockage, clean it, and re-assemble it correctly. Check the trigger operation at the carburetor to make sure that it is traveling fully from idle to full speed. Hope this helps!
Nov 19, 2010 | Husqvarna Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Garden Logo
1,481 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
