Question about Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model
Will not start
Hello, I was using this machine and it stopped working. I checked the oil and gas and they are both fine. When I pull the cord to start the machine, it will not fire up. When I tilt the machine back and pull the cord it will run, however once I lower it into the right position it shuts off again. Can you help?
  • 48 Answers
Sounds like water in the carb bowl - loosen nut on bottom of carb to drain and retighten then try to restart
Posted on Oct 27, 2008
Lawnboyoy 2 cycle runs then stops after awhile. Seems to create a vacuum because you can not pull start cord for awhile. The gas cap is vented properly
I may be wrong but this sounds like some one has been running this machine without adding oil to the gasoline or not the right mixture. If this happens the pistons and working parts seize up or almost seized. when it warms up the internal works increase in size and seize. If this happens it not worth repairing That's why you can not pull the rope. Always mix your gas right for these machines.
Jun 25, 2016 | Garden
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
My Toro mower won't start. The cord will not allow me to pull it out all the way. It seems to be caught on something.
Disassemble the starting mechanism and remove the snag in the line that is preventing you from pulling cord all the way out. Till you do that, you will be pounding salt.
Nov 01, 2015 | Toro Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
I used straight gasoline in my husqvarna backpack blower and it will not start. Is this fixable?
Hello Kelly. I don't think this connection will have good news. When gas is used in these gas/oil engins straight it usually burns them up . If you can pull the cord you can check for compression, by pulling out the spark plug and putting your finger over the plug hole. Youwill either not be able to pull cord, or piston will be stuck in cylinder. GOOD LUCK.
Oct 11, 2011 | Husqvarna Garden
Black Max 7000w 8750 surge 13hp. pulled start cord twice very hard then would no longer turn over engine, locked.
Pull the spark plug out and try pulling the cord. Sometimes it gets flooded and the cylinder fills with fuel and hydro locks. When you pull the cord and there is fuel/oil in the cylinder, it will fly out when you pull it. Stay out of the way.
If that is not the problem ( I think it is though), double check the oil level. Check the color of the oil, it should not have any silvery color. It should also not be overfull. If it is......smell it......, does it smell like gasoline? If it is overfull, and smells like gas, you have a carburetor problem. And if you do chances are you already know that, it will leak and drip, unless you shut the fuel valve off.
If everything seems fine...,and you still have a stuck motor, you will need to seperate the generator from the engine and determine which one is actually stuck.
Hope it's just a leaky needle and seat in the carb. causing your flooding.
Nov 18, 2010 | Powerware Electrical Supplies
I can't get my gas powered scooter to start. The gas seems to be running through fine but it just won't click over to start when I pull on the pull cord.
Sounds like you might need a new spark plug and/or wire. Or too much oil in the gas/oil mixture, or not enough. Could also be a problem with the pull cord, it might be disconnected on the inside.
Hope this helps =)
Aug 11, 2010 | Go Ped GSR Sport Gas Powered City Scooter
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
New lawn boy mower pull cord will not pull. Worked first 2x
Did you check the oil before you ran it. They usually come dry and you have to but oil in before running. Sounds like motor might be blown.
Aug 14, 2009 | Garden
Ryobi weed eater 30cc
Drain all the gas/oil mix out of the system. Press the red prime bulb several times until there is no fluid in the line. Pull the spark plug and clean it with a soft dry rag. Reassemble and fill tank with 2 cyl/gas mix. Prime it, then pull several times on the start cord. That should work.
Aug 05, 2008 | Electrical Supplies
Yard Machines 24a 021h700 4.5 Horsepower Chipper/Shredder/Vacuum, Push Model Logo
341 people viewed this question
Top Yard Machines Heavy Machinery Experts
donald boissonneault
rjivaro
Phil Walker
Phil Walker
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
