Question about Samsung ML 1250 Laser Printer
No paper feed
My ml 1250 refuses to feed paper. when 'printing' is required, there is just a screeching sound but no paper feed is executed. it doesn't even work with the single sheet feeder. there is a dark mark to be found at the bottom of the sheet afterwards. is there a spray or fluid that can fix that? I suppose that there is something wrong with the rubber of the intake machanism... tks!
  • Anonymous Mar 26, 2008
    My ML-1250 has exactly the same problem. I'm going to try disassembling it and cleaning the feed roller to see if that may be the problem.
  • at0mb0y Jan 22, 2009
    i disassemble it and reassemble it. I clean inside still the same probleme. the spring are not tough enough I think (that's why he takaes too much paper
IB4G2008
  • 3587 Answers
SOURCE: Printer won't stop jamming
sounds like your printer wants to form it's own three piece band(kidding here).
sounds like you rollers are dirty or have something on one or both of them..like tires on a slippery road, these need to be clean and dry.
Posted on Mar 08, 2008
  • 13 Answers
SOURCE: Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Posted on Mar 08, 2009
SOURCE: Printer paper feed wheel rubber band is broken
I had the exact sazme problem above and managed to successfully fix the probelm using an old mountain bike inner tube. I removed the cover to gain access to the paper feeder and removed it by first moving the white retaining clip on the right hand side towards the centre. Usign a flat headed screw driver I then freed this end from the black housing. Then, noting the orientation of the bar I then gently pulled it out of the gearing procket at the left hand side. This freed the bar from the printer. To get the required thickness of rubber I used four 2cm pieces cut from the inner tube and put them in place of the broken rubber. Re-assembled and worked first time and ever since. Hope this helps.
Posted on Sep 03, 2009
SOURCE: Paper Jam when using duplex function - Samsung ML-2551N
Check underneath printer.
Posted on Nov 10, 2009
  • 670 Answers
SOURCE: rubber paper feed band broke on my Samsung ML 2010
The part you need is JC73-00211A. You can buy this at printerBuddy.com. If you wish to replace this, follow this link for instructions in order to replace it. http://www.fixya.com/support/t446286-samsung_ml_2010_feed_paper
Hope this helps.
Posted on Jun 30, 2010
My printer just refuses to pick up paper. It sounds like it's going to print, then quits & red light comes on. Do I need to clean the rollers???
Yes. Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 04, 2011 | Samsung ML 1710 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
The printer either works, or it doesn't. When it
it's sounds like something is getting loose as printer attempt to print, check all the door, are any of the door becomes loose as printer try to print ?
Vinay
Feb 08, 2010 | Samsung CLP 300 Laser Printer
Red light blinking, first orange then red, toner blinks green
dear sir
  1. it is problem paper miss feed
  2. over temparature
clean thermostator.thermostator over dry toner
or cartridge assembling problem
Aug 04, 2009 | Samsung ML 2010 Laser Printer
I print a publication so I print many copies within a few days. It says Paper Jam in tray area but I can see no paper, it makes a noise and never feeds the paper.
Some Laser printers require the paper to be loaded out of the **** on one side to work well. Flip your paper **** over and try loading the paper upside down. Sounds funny but may fix your issue. Also look at the type of paper you are using your printer may need a thicker or thinner paper (look at the manual). Clean the pickup rollers!
Jul 07, 2009 | Samsung ML-2510 Laser Printer
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Samsung ml-1250 Printing stopped
Try purging the 3 pending print jobs then try to print again. Go to Printer and Faxes on XP, then right click on your printer icon then select purge print jobs. Or double-click on the printer icon on your system tray (lower right hand of the screen) then click on the pending print jobs then purge it. Then try to print again.
Oct 21, 2008 | Samsung ML 1250 Laser Printer
Constant paper jam
How do you put the paper in?It must either be the paper or the paper feed system.
Apr 27, 2008 | Samsung ML-2510 Laser Printer
Randomly printer stops printing - need switch off and on to restart printing
Sounds like you are just beginning to have problems with the paper feeding. Try cleaning the roller or applying rubber cement per my other post on the paper feed topic.
Apr 12, 2008 | Samsung ML 1210 Laser Printer
Paper won't feed
You could try cleaning the rubber feed roller with a slightly damp rag, or even having feed assy replaced but you are right probally better off replacing it.
Dec 25, 2007 | Samsung ML 1430 Laser Printer
Samsung ML 1250 Laser Printer Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
