Question about Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera
How to open the cam gently?? And replace LCD??
I broke the LCD on my Ixus 800 IS. After unscrewing all visible screws, I still could not open the camera. I didnt dare to pull hard. Anyone can help me, how and where to press, pull twist in order to open it and reach the LCD?? Thanx a lot.
Hi there. I'm a photography student on holiday who would die without her camera. I have the same model IXUS 800 IS with a broken LCD. I had to fix it. I have successfully replaced my screen and it is not as difficult as you might think. Remove all the visible screws, then the one underneath the A/V OUT flap. Next remove the long screw inside the battery hatch. This is the one that keeps the front in place, acting as a pin. The trick is you have to remove the front casing to get to the hidden screw inside. Once you have removed those first screws, all you have to do is be firm but careful and the front casing should come off no problem. After the back casing has been removed, you can replace the front so as to not lose the tiny screws, and still have complete access to the LCD and go about replacing it. Hope this has been helpful. Took me a few hours to figure it out. Ciao*
Posted on Sep 06, 2007
    Genius:
  • 2,985 Answers
Are you sure you can get the parts you need before you go further? To answer you question hidden screws can be under the mem card flap or Battery flap But I fear you wont be able to repair it. How broken is the screen?
Posted on Sep 04, 2007
SOURCE:
Screen is black when i attempt to take pic
Move all the pictures to the camera memory card from your internal memory. Since you have to open the camera, the pictures will be lost otherwise. Save your pictures. If you do not have a memory card, transfer all the pictures to your computer.
Remove batteries from the camera.
Purchase a replacement LCD screen, specific to your camera. These replacement screens can usually be purchased directly from Canon or from a camera resale shop. Auction websites should also carry LCD screens specific for these cameras. Use the mini screwdriver to remove the four screws from the back of the camera. Be careful with this step since the screws are tiny. Take the back cover of the camera off carefully. Inside the camera, there is a piece of foam that supports the LCD screen. Do not remove the foam. Set the bottom portion of the camera to the side.
Turn the top portion of the camera so it is facing upward. Notice how there are clips holding the LCD screen in place. Carefully lift these clips up and remove the broken LCD screen. The screen clips are extremely fragile and break easily if they are lifted too quickly. A gentle touch is key.Place the new screen down gently and replace the clips. Gently dust the screen so fingerprints are removed.Turn the top portion of the camera down so the screen is pointing down. Place this on top of the foam padding. Turn the screws carefully. The best way to screw the back of the camera in place is to first screw in one corner, move to the corner that is diagonally across and turn that screw. Repeat for the other two screws.Replace the batteries. Turn the camera on and see if it is function.
Thank you !!
Jun 01, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Amilo Pro V2010 base removal
Hi
The inverter is in the laptop screen, not the base.
1 remove the screw covers and then the screws surrounding the laptop screen
2 gently prise the screen bezel away from the screen, best done when the laptop is opened out almost flat
3 the inverter is at the base of the screen, gently unscrew and unclip the inverter from the LCD screen
4 take replacing the inverter to make sure all the leads are safely housed
5 replace screen bezel and away you go
Oct 11, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
How disassemble?
Open battery covering and (A/V/USB) covering - find a hidden screws there.
Aug 19, 2008 | Canon Powershot SD450 / IXUS 55 Digital...
There is a spot on the top left hand side of the LCD monitor, and this spot also appears on the prints
Looks like dust must have gotten onto the CCD sensor (or, more specifically, onto IR-cut filter on the sensor). The dust enters the lens through the gaps between zoom barrels and sometimes ends up on the sensor-which is what most probably happened here.
There are 2 ways I know to remove the dust. 1st way-it might sound silly, but try sucking the dust from the camera with your mouth around the closed lens :) Make sure you don't blow any air in. This worked for me a few times. Note that sometimes it might make the problem worse as you might move other dust particles onto the sensor.
If 1st way didn't help then you can try directly blowing the dust off the sensor. This should only be attempted if you're happy with partial dismantling your camera and are ok taking the risk of ruining the camera further. Although in my opinion lumix cameras are generally fairly easy to repair, you will need steady hands and patience to attempt this. If you are happy to proceed, do the following:
1. unscrew the screws holding the back of the case
2. lift the case carefully a bit making sure you don't break the ribbon cables going to LCD and backlight
3. undo the LCD and backlight ribbons (there are black flaps on the connectors, these gently flip upwards)
4. gently remove upped logic board. Try to pry it in stages from all sides, don't just pry it up in one go from one side or you might damage the connector. (I learned the hard way ;)
5. on the bottom logic board you'll see 2 connectors, undo the upper one to release the ribbon going to the sensor (note that this is not absolutely necessary if you're happy cleaning the sensor without disconnecting it-it can be done, the ribbon is relatively robust.)
6. the sensor is held by 3 tiny star screws. if you don't have the exact screwdriver you should be able to use a small flat screwdriver to carefully unscrew them. Do the screws bit by bit, i.e. unscrew 1st one a bit, then unscrew 2nd one a bit, and so on
7. there is a small spring underneath the sensor assembly, make sure you don't lose it :)
8. once the screws are undone you have access to the sensor-lift it up. Under good light you should be able to see the dust bits. Use a blower to get rid of them.
9. that should be it. put the camera back together. figers crossed it will power up and the dust problem will be gone :)
NB. You might have come accross horror stories of people being electrocuted by flash capacitors when repairing cameras. This might indeed happen. It's not easy with FX8 though: To get electrocuted here you would need to undo the top plate, unscrew the switch logic board and remove protective tape off the flash circuit, then touch the capacitor contacts :) Don't do it of course. Not worth it.
Good luck,
Raf
Jun 21, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
How do you take the camera canon powershot SD550 apart?
Hi Wolfy43
I have the Australian version (ixus750) of your camera.
DON'T try to force it open!!!
make sure you have the extra screw out from the button end, behind the grey cover 1 screw is visible from the outside there is another under the flexible cap. Once the end is off there is another screw with a bigger flatter head than the rest near where the flexible cover closes.
With all these screws plus ALL other visible screws out lightly twist the case.
The left end (from the back) should then come away a that end then gentle lift the back case off pulling from the left end.
there are 3 small clips that catch on the front 1/2 of the case.
Hope this helps
May 10, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Memory
You've to see at the back of your notebook, you have to unscrew that say say KB. Incase it is not written then unscrew all the top and middle screw.Some model after unscrew you have to remove the front panel first before removing keyboard or some model remove the front panel and KB screw is underneath it.By saying Front panel, I mean the panel at top where you press power-on button and all.
Apr 18, 2008 | Compaq Armada E500 Notebook
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD700 IS Digital ELPH / IXUS 800 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
