Question about Dell Computers & Internet
"A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER. IF THIS IS THE FIRST TIME YOU'VE SEEN THIS ERROR SCREEN RESTART YOUR COMPUTER. IF THIS SCREEN APPEARS
"A PROBLEM HAS BEEN DETECTED AND WINDOWS HAS BEEN SUT DOWN TO PREVENT DAMAGE TO YOUR COMPUTER. IF THIS IS THE FIRST TIME YOU'VE SEEN THIS ERROR SCREEN RESTART YOUR COMPUTER. IF THIS SCREEN APPEARS AGAIN FOLLOW THESE STEPS: CHECK FOR VIRUSES ON YOUR COMPUTER. REMOVE ANY NEWLY INSTALLED HARD DRIVES OR HARD DRIVE CONTROLLERS. CHECK YOUR HARD DRIVE TO MAKES SURE IT IS PROPERLY CONFIGURED AND TERMINATED. RUN CHKDISK /F TO CHECK FOR HARDDRIVE CORRUPTION, AND THEN RESTART YOUR COMPUTER. TECHNICAL INFORMATION: ***STOP: 0x0000007B (0xF7B6D528, 0xC0000034, 0x00000000, 0X00000000) " in dell laptop
2 Suggested Answers
  • 1705 Answers
SOURCE: laptop issue
You've not posed a question, this looks like a cut and paste of the typical report from a blue screen crash.
Just follow the instructions :-
1) IF THIS IS THE FIRST TIME YOU'VE SEEN THIS ERROR SCREEN RESTART YOUR COMPUTER.
2) IF THIS SCREEN APPEARS AGAIN FOLLOW THESE STEPS: CHECK FOR VIRUSES ON YOUR COMPUTER.
3) REMOVE ANY NEWLY INSTALLED HARD DRIVES OR HARD DRIVE CONTROLLERS.
4) CHECK YOUR HARD DRIVE TO MAKES SURE IT IS PROPERLY CONFIGURED AND TERMINATED.
5) RUN CHKDISK /F TO CHECK FOR HARDDRIVE CORRUPTION, AND THEN RESTART YOUR COMPUTER.
Posted on Jul 19, 2010
Blue screen error plus blank start up screens but the start up sound can be heard.
Have you changed any BIOS settings? I would open your BIOS menu and make sure it is set to "AHCI"
Aug 21, 2012 | Lenovo IdeaPad U550 Notebook
A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you've seen this Stop error screen, restart your computer. If this screen...
Hi dipudps...
Download,install and run Microsoft Safety Scanner....after the scanner has run and cleaned the computer see if that solved your problem.
If you have a virus,worm,trojan,etc on your computer.
Go to the following website and download,install and run the FREE Microsoft Safety Scanner.
It will remove the virus,trojan,worm,etc from your computer.
It may take quite a while to finish, it all depends on the size of your hard drive.
Once the Microsoft Safety Scanner is completed running, it should have removed the virus,trojan,worm,etc. from you computer, but if it didn't remove the virus,trojan,worm,etc from your computer then it will give you an option to connect (real time) with a Microsoft professional (FREE) and he will take over control of your computer (with you permission) and finish the removal process.
Please take time to rate me thumbs up
http://www.microsoft.com/security/scanner/en-ca/default.aspx
Sep 12, 2011 | HP Pavilion dv6000z Notebook
Dell inspiron mini 10 Turn it on, put in password. screen says windows did not start up sucessfully. A recent hardware or software change may have caused this. then i go to the last known good...
A blue screen with white writing appears on my computer,
just before windows is about to begin and it reads:
UNMOUNTABLE_BOOT_VOLUME
If this is the first time you've seen this stop error
screen restart you're computer.
If this screen appears again follow these steps:
Check to make sure any new hardware or software is
properly installed. If this is a new installation, ask
your hardware/software manufacturer for any windows
updates you might need.
If problems continue, disable or remove any newly
installed hardware/software. Disable BIOS memory options
such as caching or shadowing. If you need to use safe
mode to remove or disable components, restart your
computer, press F8 to select advanced startup options,
and then select safe mode.
Technical information:
STOP: 0XOOOOOOED
(OX8OED4AF8, OXCOOOOO32, OXOOOOOOOO,OXOOOOOOOO)
I cannot go into windows even in safe mode, and I don't
know how to execute any of the other things it's telling
me to do.
It may have something to do with my virtual memory as
windows had to increase it while I was playing a computer
game, or because I added some extra pictures I downloaded
to a computer game folder where the default pictures were
already stored.
if u cant do these then reinstall the operating system.
Sep 03, 2011 | Dell Inspiron Mini 10 Notebook
It will not boot in safe mode. It will not boot to last known good configuration. . On the blue screen "A problem has been detected and windows has been shut down to prevent damage to your computer. ...
This error refers to an inaccessable boot device. I typically will fix this error by booting the PC from another form of boot media (Example: Linux Ubuntu) to access the files. But to make it simple for any user, you will want to buy a replacement hard drive, that your system can support.
Cut power to the PC. Physically remove the damaged drive. Install the new replacement drive, and install your recovery CD to this drive. Once the system is back online from Recovery, you can re-connect the damaged drive, as a slave, to retrieve the data.
Most new systems will allow both drive to detect in the system if you set the jumper on the end to Cable Select (CS). If you have SATA drives, Master/Slave doesn't apply.
Beyond this point, if the drive will not allow access to the files, you will have to follow the same method, but try installing some free File Recovery Tools to scan the damaged drive with, like PCI File Recovery.
Contact me if you would like more detailed instructions sent to your email. You will have to send me a make and model of the PC though.
Aug 23, 2011 | Dell Dimension 8400 PC Desktop
I open my new laptop (Toshiba) when i try to boot the system and instal windows XP this message was appear: A problem has been detected and windows has been shut down to prevent damage to your...
Hi. You need to try install other higher windows version like windows vista or windows 7.i already encounter that problem i fix it using windows 7 installation.try it's work.
Jun 03, 2011 | Computers & Internet
"A problem was detected and
Re boot in safe mode if normal boot is not possible and run CHKDSK/F
DO NOT DISABLE ANTIVIRUS!!!!!!
That should sort hard disc errors out then download iobit.com and run the registry utility, that will remove more errors. It is a free ware programme and works very well.
Hope that sorts it out for you.
Feb 26, 2011 | Computers & Internet
Laptop issue
Jul 19, 2010 | Acer Aspire 5610-4648 Notebook
Xp not install in compaq presario cq50 139wm
In Windows XP, The STOP: 0×0000007B: error often occurs if you move a hard drive that contains Windows XP to another computer or if you have just installed a newmotherboard or drive controller. This error occurs in these cases because your registry does not contain driver entries for the current motherboards drive controller. So in effect, the device driver that Windows XP is loading from the registry will not work with the new drive controller.
Fixing the STOP: 0×0000007B: Error:
The easiest approach to fixing the error is to locate download and install the latest hard drive controller driver for your motherboard. In many cases the driver in question controls a ATA or SATA device.
There are other problems including viruses that can cause this error and information regarding these causes can be found HERE
Jan 01, 2010 | Computers & Internet
I received the following stop-error screen: "A problem has been detected and windows has been sut down to prevent damage to your computer." TECHNICAL INFORMATION: ***STOP: 0x0000007E (0xC0000005,...
You Need to reinstall the windows and clear all previous data from your computer and disassemble any new hardware if u attached with your board ok your problem will be solved OK best of luck .
Mar 07, 2009 | Computers & Internet
Computers & Internet Logo
55 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
