Question about SimpleTech (sti-u2f36/250) 250 GB Hard Drive
My 250gb simpletech is not recognized by my laptop.Power is displayed, 4 blue lights corners lit up and then goes out.
  • SimpleTech Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Feb 22, 2012
5 Suggested Answers
nicgan
  • 5 Answers
SOURCE: simpletech 250GB STORAGE S
try plugging your HD into another desktop/laptop to see if your HD is functioning well on a different computer. Could be the USB cable problem.
Posted on Feb 13, 2009
bronk50
  • 27725 Answers
SOURCE: when turn on my simpletech 250GB device its say
control panel admistrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
ports(com&lpt)right click update driver or
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Posted on Dec 31, 2010
jgroves705
  • 536 Answers
This sounds like your USB bus does not have enough power available to run all devices that are connected to it.
If you are using a USB HUB, this is not unusual.
Try disconnecting other USB devices to see whether that allows the external drive to function properly. If it does, then I suggest that you get a "powered" USB hub to use to connect all of your devices.
GodricHamber
  • 38 Answers
SOURCE: My new Laptop with Windows
If your hard drive can bedetected and shows up as a drive letter in my computer but you can't access oropen your files,then you can recoveryour data from hard drive with data recoverysoftware easily.This way is the easiest and the most inexpensive way for hard drivedata recovery.If you bring it to Best Buy or a professional,they will costyou $500-1000 or more.
I managed to recover data from crashed hard drive with Tenorshare DataRecovery.If needed,you can download it and scan your hard drive for free topreview whether your data can be recovered.It will show you the filename,type,date and of your files and thumbnails for pictures that it foundon your drive. Get it from http://www.any-data-recovery.com/product/datarecoveryprofessional.htm
If it fails, you will have to bring it to Best Buy or a professional but let'shope not because it will cost you a lot of money ($500-1000 or more) andwhether they can recover data is not guaranteed.
Posted on Sep 07, 2011
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Where can i get the installation softare for simpletech 250???
you can check on the official site from here http://www.simpletech.com/commercial/products/simpledriveexternalpininfarina.html ;you need to plug in USB to be recognized by you PC or laptop after that you can acces your hard drive when is instaled make a reboot to be sure that is instaled properly.
Dec 10, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech external harddrive, blue flashing light with a constant beeping
Your drive is not getting enough power. try a different usb cable and a different usb port on the computer
Sep 26, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250GB STORAGE S
Feb 01, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Simpletech hard drive not working
I have that problem similiar to yours. My simple tech stopped working for like two years so i decided to open up my simple tech and removed my HD away from the old enclosure so I can try building my own external hard drive for the first time. I bought another new 3.5 enclosure, IDE/ATA for the old HD. I put it in the new enclosure and it worked!
It's the only solution you can have. No need to retrieve data or re-format your HD. You can leave it the way you like...if you wanna reformat it...up to you.
Jan 27, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
My computer won't recognize the drive
check the power for the drive and also try changing the cable.
does the system display that usb device not recognised if it doesnt then the problem is with the wire.
Nov 08, 2008 | SimpleTech Signature Mini 250GB External...
Does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
Dec 06, 2007 | SimpleTech SimpleDrive 250GB, 7200RPM,...
SimpleTech (sti-u2f36/250) 250 GB Hard Drive Logo
142 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
