How do i get driver speaker working
Someone disconnected the wires for the warning chimes, now the driver speaker doesnt work
emissionwiz
  • 75807 Answers
SOURCE: warning chime disconnect
You will have to disconnect the warning chime module, it is on the driver side under the dash, follow the sound, it is about the size of a pack of smokes, it is usually black in colour.
Posted on Oct 29, 2008
goalie39
  • 469 Answers
SOURCE: 99 new beetle- warning chimes not working
Have you checked the fuse box, it may be on an obscure circuit. check each and every fuse closely.
Hope this is of some help.
Posted on Apr 20, 2009
alicantecoli
  • 22133 Answers
SOURCE: 2006 GMS Sierra Z-71
run the wires direct to the speaker is the answer ,must use a module ,my way to overcome this without paying silly money to a dealer fitter **** with neoprene gloves on and white coat who thinks he knows it all, is a back to basics and run my own wires and by pass the on board computer
Posted on Jun 20, 2009
  • 37 Answers
SOURCE: Drivers side seatbelt connected When truck is
sensor in the seat belt bukle needs to be replaced
Posted on Aug 01, 2009
  • 36 Answers
SOURCE: no warning chime for 2006 Ascender
I don't think it is a fuse.
The warning chimes for this vehicle come through the radio and are play to the speakers and if I remember correctly the chimes play to the left front speaker.
I would check for a faulty speaker or wiring to the speaker.
Posted on Oct 19, 2009
My aftermarket radio is not working in my 2005 Chevy equinox. Do anyone know why? It's a new radio and all of the wires are connected properly. The chimes stopped working as well. Fuse are new as well
The chimes work through the factory radio , come out driver door speaker . There is a interface module you need to hook up on GM vehicles so aftermarket radios will work . With these newer vehicles your better off taking to someone or place that does this on a daily basis . Does it start an run ? If it does i'm surprised , factory radio is also hooked to the vehicle serial data network , class 2 . Suggest you google that .
Battery positive voltage is provided to the radio from the Radio (15A) fuse in the fuse block. The radio is grounded through a braided cable case ground. The radio is enabled/disabled by Class 2 messages from the body control module (BCM). The entertainment system on this vehicle is configured with a base and uplevel system. The base and uplevel systems contain a radio, antenna, speakers, and on some vehicles an audio amplifier.
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings. The BCM receives audible warning requests via the class 2 serial data line or the controller area network (CAN) data line. If the BCM receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime--200 pulses per minute
Medium rate chime--150 pulses per minute
Slow rate chime--50 pulses per minute
Single chime
Mar 15, 2017 | Cars & Trucks
2004 chevy Trailblazer seat belt chime doesnt work ?
Lots of owners would like to kill the seatbelt warning if they could.
If the car is fitted with airbags and connected pyrotechnic seatbelt retractors as part of the SRS fault finding in that area can be potentially explosive for the inexperienced and should not be undertaken without taking sensible precautions and access to a wiring diagram to ensure the correct wires are being tested.
The chime might not be working because the switch within the catch is faulty or stuck. The manufacturer will probably suggest such things as disconnecting the vehicle battery and waiting for half an hour before disconnecting the pyrotechnic unit and proceeding to check the circuit wiring.
May 30, 2016 | 2004 Chevrolet TrailBlazer
Is there a way to fix the the turn signal chime and other various chimes on a 2009 Chevrolet Cobalt LS, there is no sound from them as well as front speakers?
The audible warnings alert the driver of a system concern or a critical vehicle condition. The radio generates the audible warnings through the speaker. The radio receives audible warning requests via the serial data circuit. If the radio receives multiple audible warning requests, the warning with the highest priority sounds first. The following lists the audible warning priority and the pulse rate:
Fast rate chime (200 pulses per minute)
Medium rate chime (150 pulses per minute)
Slow rate chime (50 pulses per minute)
Single chime
May 13, 2016 | 2009 Chevrolet Cobalt
How do i disconnect fuse to seat belt alarm tried three time method didnt work
The seat belt warning chime is controlled by the central timer module ! You can't just disconnect fuses , other things may stop working !
Safety Belt Warning Indicator Lamp and Chime
The safety belt indicator and chime feature is controlled by the CTM. The driver safety belt switch is hardwired to the CTM. If at any time during the first 60 seconds after the ignition switch is placed in position II, if the driver safety belt is sensed as being unfastened, the CTM will process the input, and in turn, output a signal to the CTM through a hardwired circuit. In turn the CTM will output a visual warning to the instrument cluster. If at any time during the first six seconds after the ignition switch is place in position II and the safety belt is not fastened, the safety belt warning chime will sound.
When the seat belt is connected the warning still chimes ? Could have code stored in the CTM .
B1464 Safety belt switch circuit short to battery CTM Go To Pinpoint Test B .
SoW
Jun 30, 2015 | 2002 Ford SVT Focus
How do I disconnect the chime from automatic door .Had to cut cable as it jammed . Took out fuse but radio and clock now do not work .Can I disconnect wire from chimes .I knoe it comes from speakers .
try this
disconnect battery
undo the fuse box and look at the wires behind that fuse you pulled
check that only radio and clock wiring are fitted there
the chime may its own power source
i could be wrong
i thought chime was separate to sound system speakers
and comes from a small but loud sound device on the instrument panel circuit board ..much like a computer
May 28, 2014 | 2005 Buick Terraza
2008 Cobalt - Front speakers not working and no audible turn signal. Both stopped working at the same time.
In my 2008 Cobalt, the front speaker in the driver door went inoperative - no turn signal noise, no warning chimes for door open with key in, seatbelt chime, low fuel chime, and of course, no music. All of those sounds come through the speaker. I switched the driver door speaker and the passenger door speaker, and now I have all of those noises back.
If you have manual roll down windows, you'll have to buy a special tool to remove a little clip that's behind the roller handle. This tool was included in a kit for about $7 that I bought at Harbor Frieght, but you might be able to find the kit at other auto parts stores. Google "removing window crank" and you should be able to locate a video that shows how to get it off.
Anyway, I switched the speakers and now we just don't have music coming out of the passenger door speaker, but at least we have all of the warning chimes and turn signal clicking noise again.
The dealer wanted almost $200 for a new speaker and to replace it (labor). Rediculous.
Jul 20, 2010 | 2008 Chevrolet Cobalt
Where is the door chime on a1995 mercury grand marquis
It's the same as the lights left on and the key in door open its called the generic eletronic module and it's in the dash to the right of the steering collum. Why do you want to know as all kinds of things are run by this device and it costs plenty. If it keeps chimbing and you want to stop it all kinds of things don't work with it unplugged ( interior light's cruise control, air conditioner and heat,Radio,Automatic headlights. Daytime running lights) If its saying the doors open, it is! Just because it looks closed doesn't mean that they are the most likly is the driver door and the switch is in the door latch that holds the door closed. The switches rust break fall off or get disconnected. worset problem is the wire from the switch breaks in the door hinge area and the wire will need to be found and replaced or repaired. The modules seldom fail unless submererised in water or the battery hooked up backwards or jumped off wrong battery cable removed while the engine in running but alot of this other stuff will work wrong too.
Dec 05, 2009 | 1995 Mercury Grand Marquis
No warning chime for 2006 Ascender
Sep 09, 2009 | 2006 Isuzu Ascender
Warning chime disconnect
Oct 26, 2008 | 1994 Ford Escort
13 people viewed this question
 Grubhead
Grubhead
