When i print using letter size document, it will copy/print 2 sides even though i only have one side to be printed. The 2-sided printing will function even though the setting is 1-side/default.
SOURCE: My margin gets cut off on one side whenever I make copies
Are you copying onto the same size of paper or onto another size like A4? If changing size you will have to tell the machine what sizes are in use.
If you are using similar sizes, try setting off a stack and as the machine feeds a sheet in, turn off the power. Lift the lid and see iff the page is running in the correct position and not off to one side. If the page is off to one side, you need to check that you have the paper guide (where fitted) pushed up to the correct position etc.
Let me know if this helps any.
SOURCE: copies print with horizontal lines
thin lines? spaced about 1.5 inches apart could be toner left on the drum, take the cartridge out turn it over and retract the shutter, manually turn the drum using your thumbs on the edges of the drum, do you see thin lines on the drum? sometimes something sticky gets on the drum attracting toner and then it transfers to the paper during the copy process
SOURCE: Konica/Minolta majicolor 2300DL printer
pleas check the driver settings, maybe there is a setting fit to paper or something.
SOURCE: my Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
SOURCE: sending print job from pc to IR5000 prints with missing letters
I doubt it's the copier, sounds more like a application or board problem, my first suggestion would be to re-install the driver. the other would be to target the hard drive or memory/ mother board of the network of the copier
