Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
What else besides a belt would cause a dryer not to rotate
    Problem Solver:
  • 9 Answers
Motor, start capacitor, If its making a buzzing noise and the motor wont start most likely its the start capacitor.
Posted on Feb 21, 2012
Loud, low (bass) noise, not coming from the vent or the heating element
Most probably caused by one of the belts being frayed and about to break. You might want to replace the small drive belt (00096426) first as it does the most work of transferring the motor power to the shaft causing the drum to rotate. A worn belt can cause a low frequency hum and potentially slow down drum rotation as it slips on the hubs. Replacing the large drum belt requires a lot more work than the drive belt because you must remove both the front and side panels of the dryer; whereas, the drive belt is accessed by removing the right side panel.
Apr 25, 2015 | Bosch Axxis WTA 3510 Electric Dryer
My electric LG dryer's drum is no longer rotating,
more than likely the motor fan jammed by a sock (or something of that size) that made it around the lint filter; sucked down into the fan. probably not a belt.
May 29, 2011 | LG DLE5977 Electric Dryer
My maytag dryer has a loud squeal. I replaced the belt, but the squeal persists
Check to see if the belt has landed in the groove instead of on the outside of the drum. One might assume that the groove is there for the belt, but inspection of the drum will show previous belt location about an inch beside it. To fix, rotate the drum counter clockwise while pulling the belt away from the groove on the bottom of the drum. Once it has rotated a complete revolution, it should be in alignment and the noise should disappear.
Jan 14, 2011 | Maytag MDE8000 Dryer
After replacing my belt and drum rollers my roper dryer has a clicking noise as it rotates
Could be a lot of things causing it, blower wheel, motor, idler pulley, rollers. Dryers have several moving parts that could cause a clicking sound. The blower fan could be coming into contact with something. There is a motor, tensioner and a belt that turn the main drum, the tensioner for the belt could be loose thus causing the clicking noise as well.
Oct 16, 2010 | Roper REX3614KW Electric Dryer
Dryer does not rotate, makes buzzes as if wanting to start rotation
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2010 | Whirlpool Dryers
Kenmore gas dryer drum does not rotate
The most probable cause is that your motor went bad....
Check out this tip...it will help you..
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 29, 2010 | Kenmore Elite HE4 Electric Dryer
Rattles when drying
I need more details but typically a dryer will make a rhythmic rattling noise when loose change and other small metallic objects as well as buttons become trapped in the tumbler impellers (those wing shaped things in dryers).
Loosen and remove the top of your dryer.
Rotate your drum, taking care not to rotate it the wrong way. The right direction of rotation will produce friction to the belt, the wrong direction will cause slack on the belt on one side or the other of the drum.
Rotate the drum until the back side of the impeller is directly on top with the outer screws facing you at the top of the dryer. Remove the screws and pull out the impeller and you will find your noise makers. Do this with the remaining impellers and reinstall.
Mar 05, 2010 | Dryers
Dryer turn on but would not spin
When the dryer will not spin the most common cause is a broken dryer belt.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Sep 14, 2009 | Kenmore 63942 Dryer
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Jan 28, 2009 | Whirlpool LEW0050P Electric Dryer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
59 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
