Question about Logitech Webcam
It will not turn on by itself
I want to be able to have my webcam on all the time
My Logitech webcam has a twist focus thingy on the top but it won't turn anymore I tried cleaning but it still didn't twist
Not sure what you mean by "on the top". The focus is usually a ring around the webcam lens itself, not on top. Can you tell us, please, exactly which webcam you have? The webcam may have some small print that identifies it, or look Control Panel / Device Manager / Imaging Device to see the brand and model number.
Aug 14, 2014 | Logitech Webcam
Webcam doesnt work
Restart the computer and see if the blue light comes back on by itself. If you are still having problems visit the Toshiba support site for your country (or region). Download the webcam application compatible with your version of Windows (32 bits, 64 bits) and reinstall the application. Test it using the Start>Toshiba>Utilities>Webcam Application, or the Face recognition software. You close the running application by clicking the x at the top right corner of the application window
Oct 27, 2013 | Toshiba satellite c660
Webcam lights
You need to provide info about which model you have, there are so many different problems with different series.
Aug 30, 2013 | ASUS Computers & Internet
DELL WEBCAM BECOME GREEN
Dell webcam manager is a utility used to control the webcam functions. You can follow this link to download and install: http://dell-webcam-manager.software.informer.com/download/ There is also, dell webcam center, which can also be used to configure the webcam: http://dell-webcam-center.software.informer.com/download/ If neither of these work and reinstalling the drivers has not been successful, I think the webcam itself is the problem.
Mar 28, 2012 | Dell Computers & Internet
How do i turn on the webcam on my HP G71? it worked by itself before but now it tells me i have to turn it on?
Webcam can be accessed only through certain programs that support it. The most popular ones are VoIP and IM apps. You can view the webcam using a software called Cyberlink YouCam. Download Now!
Dec 06, 2010 | HP G70-250us Notebook
My laptop acer aspire 5740 is not recognizing its inbuilt webcam when i install driver it asks to plug in the webcam.how will i plugin the inbuilt webcam!!!!!!!!!!!!!. i even formatted it and reinstalled...
The problem may be with the camera itself. It is asmall device that sits behind the screen bezel and is attached to the motherboard using a long flat cable. There are times that the cable itself maybe bad, or the plug on either end. It could be that the plug has come dislodged from the motherboard or the camera itself. To check to see if the cable or camera is bad, you will have to disassemble the laptop to get to both the mounting area behind the lcd bezel and the keyboard and palmrest to sccess the cable on the motherboard. The cable itself may need replacement. I have purchased several of these on Ebay with success.
Jul 23, 2010 | Acer Aspire 5315 Notebook
I have an Acer 4736z and i have a dual OS...my
update the driver for Vista environment
Aug 31, 2009 | Computers & Internet
Hooked up my web cam and picture is blurr
if the webcam is a budget webcam and the picture looks ok when staying still but is blurry when moving, then there is nothing you can do, that is how the webcam is for the fact it is a budge, low price webcam
if the picture is blurry all the time, usually, around the lens, you can turn something to sharpen the picture up, eg, some cameras you turn the lens's basal itself and it move the lens back and forth changing the focus
Dec 27, 2008 | Logitech Webcam
Won't work on yahoo
Yes, just make sure its only Yahoo since you can't use your webcam on multiple applications at the same time. Only 1 at a time.
Try this and tell me what will happen..
1. Open your main Yahoo Messenger window
2. Click on Messenger on the Menu bar and click Preferences
3. Go to Webcam option and click Camera Source
4. Check if your webcam is listed - if it is, make sure its the one selected
Then try to check if you can start your webcam on YM. Goodluck!
Nov 07, 2008 | Microsoft LifeCam VX-6000 Webcam
Philips pc camera SIC4750/27
Normal 0 How much memory do you have installed in your computer? It may need to be, increased, as this is likely to be the cause of your computer freezing, rebooting, times out, or shutting down.
Hope this is of some help. Bud
Oct 02, 2007 | Philips J44414
Logitech Webcam Logo
21 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
