Question about TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE
Wiring Schematic needed for Titan Tankless Water Heater N-120
5 Suggested Answers
SOURCE: Titan Tankless stopped working this morning.
I have the Titan SCR2 N-120. You may have a different model. On mine if you are looking at it just a inch below & 1 inch to the left of dead center will be a round black sticker(it has some white lines at&t's logo). there's a pin hole in the middle of the sticker that you can poke to reset. Or turn the breaker off then take the 2 screws out of the top of the unit. It's just a thin metal cover that you can pull back & look inside. You'll see a red circular button thats the reset button. It's right behind where the hole I was talking about & what gets pushed in. you'll also be able to see if anything burned out & can get replacement parts at titanheater.com . One of my heater elements had burn/ melted & I've ordered a replacement. It was $17 + $11 s&h but still cheaper than $200 new unit from e b a y. Best of Luck
Posted on Sep 05, 2009
  • 44 Answers
SOURCE: Titan tankless hot water heater will not go off standby.
There are FAQ's at the following location:
http://www.titantanklessheater.com/page/1227557
Could be a few things. Most common are reversing the water flow (putting your cold water input into the units hot output instead of the other way around) or not bleeding the air out of the unit (running water for a minute with the unit off) before using it. Could be a bad flow detector switch or an internal malfunction as well. If you review the link above and my tips and don't find anything then contacting the company is probably your best option.
Posted on Oct 10, 2009
packrat1948
  • 528 Answers
SOURCE: I have a titan 120
Replace the element it is shorted out.
Posted on Feb 02, 2011
Testimonial: "I ordered one Monday. Just wanted to make sure I was doing the right thing. Thanks"
heatman101
  • 43501 Answers
SOURCE: No Hot warer frpm our
The water is dripping from the connection because the connection has cooled as a relut od the hot water not keeping it expanded...
Now... the tank may not be heating for many reasons....first check that you have power going to the heater...
Then make sure the reset button has not tripped...if it continues to trip then you have a problem... usually with the thermostat...
If that is not tripped then the thermostat could be bad...and not sending power to the heating element...
If you have power to the heating element and no heat then the element burnt out...
heatman101
Posted on May 30, 2011
I have a Titan water heater model N-160. I turned the water off hoping to change the filter. Now There is no hot water and the screen reads : STAND BY FLOW=OFF how can I reset it?
Hey Shawn..did you turn the water back on BEFORE cutting the electricity back on? Cut the breaker off,,, wait 3-4 minutes before restarting.. MAKE sure the water is on ALL the way...
Troubleshooting the Titan tankless water heater
SCR3 160 Titan Tankless Water Heater
Jul 02, 2017 | Water Water Heaters
Need a wiring schematic
Copy following link for tank-type electric water heater wiring:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
For tankless electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
For tankless gas, hybrid, combo, boiler, indirect, solar, heat pump, etc then re-post question with specific brand and model number for possible help
For switches, timers, lights etc:
http://waterheatertimer.org/How-to-wire-switches.html
Oct 31, 2012 | Water Heaters
Will my rheem tankless water heater work without the main remote hooked up
Yes.
Default temperature will be 120 degrees F
Of course the tankless still needs to be plugged into a wall outlet.
Copy following link:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#remote
Oct 06, 2012 | Rheem Tankless Water Heater Main Remote...
The titan water heater does not heat. The unit shows that it is on.
Most likely it is because the heating element is burnt out inside the heater....
You will need to replace the heating element or replace the heater...
heatman101
Feb 01, 2011 | TitanNet TITANTANKLESS. COM PRESENTS THE...
I have a brand new Titan N-120 that melted the first 8' of the inlet pipe until it blew apart at a fitting. Is this a flow detector switch problem?
No. It is a limit switch malfunction and a temperature and pressure relief valve problem. The safety valve should have opened before any melting occurred. You do have a TP&R valve, right? Depending on how new the unit is, you should contact the manufacturer for a new heater; dont take a chance.
Dec 20, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Scr2 titan water heater. No hot water. Both red
On the left side of the board there is a 10K 5Watt resistor that gets loose from the board because of overheat and it needs to core solder back with soldering iron.
Apr 28, 2010 | TitanNet TITANTANKLESS. COM PRESENTS THE...
Jul 27, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
The Titan 120 will not turn off. Is it the thermostat?
It sounds like maybe there is a build up of sediment. You can clean that out. Contact Titan tech support like at 888-Titan-80 or email then at Titantech@engnieer.com
Jul 02, 2009 | TitanNet TITANTANKLESS. COM PRESENTS THE...
TitanNet TITANTANKLESS. COM PRESENTS THE TITAN SCR2 WHOLE HOUSE TANKLESS WATER HEATE Logo
29 people viewed this question
Top TitanNet Water Heaters Experts
Donni Steen
Gil Shultz
Are you a TitanNet Water Heater Expert? Answer questions, earn points and help others
