Question about Frigidaire Refrigerators
Frigedair FRS26R4AB6 side_by_side icemaker doesnt make ice and sometimes the water over flowes and freezes in the tray
Frigedair model FRS26R4AB6 side_by_side ice maker doesn't make ice anymore. It will overflow while filling up the water tray and freeze.
dididsaythat
  • 291 Answers
SOURCE: Hotpoint HSS25GFP icemaker stopped working
are u sure that model # Is right.. DOnt come up in any of my model data bases Seems like u might of got a bad icemaker.. if the water is coming into the icemaker from the water valve.. icemaker has to have power, to do that... all funtions after that would be controled by the iceaker .. The only other thing i can think of is your refrigerator has to be a certain temp to activate icemaker somewhere around 0 give or take some to be safe
Posted on Aug 21, 2007
SOURCE: Water doesnt stop after ice tray is filled
My amana sxd25s2w side by side, water dispener just stopped working all at once. I hear a click when pushing the bar, and the light goes on but no water. Also the ice maker is over flowing when it fills the tray. Are these 2 things related and I would like to replace the filter for the water , where can I find that. Please help!
Posted on May 04, 2008
22yooper
  • 828 Answers
SOURCE: ice maker over flows with water
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Posted on May 13, 2008
  • 489 Answers
SOURCE: water wont flow into LG LX259602b ice maker
You may have a bad water valve.  The valve has 2 sections, one for the water dispenser and the other for the ice maker.  Check those connections in the back of the refrigerator.  If everything is ok, replace the water valve.
Posted on Jun 08, 2008
SOURCE: ice maker leaking
what is the model number of this fridge?
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Posted on Jul 23, 2008
Ice maker not making ice
Not sure what model you have, but recommend you check to see if there's not a cube stuck in the dispersal unit. If not, then check plastic water supply tube in the back of the icemaker, sometimes they freeze solid and won't let water flow into the ice tray. I've had to use a hair dryer to defrost it if the freezer temp gets too low. Also, sometimes the ice maker inadvertently lets too much water enter the trays and it slightly overflows, which results in the freezing of the gears and paddles of the maker and you simply have to chip away the excess ice that overflowed the trays. If none of the above are the case, make sure you still have a solid water supply to the back of the unit, if the line runs outside of the heated portion of your home, it could have frozen outside of the fridge. Hope this helps.
JB
Mar 03, 2011 | Maytag Refrigerators
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
Ice maker is not making ice, but water from door dispenser flows normally. Ice in the tray (where it is made), but it won't dump into the holding tray. any solutions?
Greetings,
The first thing to check is the tube that puts water into the icemaker...this sometimes freezes up from a leaking water fill valve..if so, this blocks the water from filling the i/m....if its not frozen up and is clear(open) then your fill valve is bad or your icemaker module(if equipted) with that style...
Dec 14, 2010 | Frigidaire Refrigerators
Ice cube maker does not work what can be the poblem
first of all assure that u are getting water inside of the tray of the ice maker if you have no water then u will want to ceck in the back of the unit down the bottom a blue or white plastic piece this is called the water valve assure that u are getting water through the tube into the icemaker sometimes on some units there willbe a freeze up in the line if this is the case then you would have to defrost the line itself if your unit is getting water and u can feel ice on the inside remove the entire icemaker unit and run hot water to remove all frozen ice then reinstall your doing this becasue sometimes the gear cannot turn becuase it comes out of postion and sometimes this does make the gear go back to normal after u install you would have to wait till your icemaker once again reaches 30 degrees and then it would start making ice again if it doesnt not make ice at this point then u would have to buy a new ice maker cheapest way ton get a new icemaker is through marcone appliance parts and they will ship it to your door hope this helps
Jul 18, 2010 | KitchenAid KSCS25FKSS Side by Side...
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
Icemaker making small amount of ice
I RESET THE SWITCH ON THE ICE MAKER AND TURNED THE TEMP TO 9 FROM 5 AND IT STARTED MAKING MORE ICE. I'M NOT SURE WHAT WAS WRONG BUT IT APPEARS TO WORKING FINE NOW.
Dec 04, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Icemaker
IT DOESNT MEAN YOU GETTIN WATER IN THE WATER DISPENSER THAT THE VALVE IS OK.MOST FRIDGES ARE FITTED WITH TWO VALVES.CHECK THAT THE ICE MAKER VALVE IS WORKING IF THATS OK YOU MIGHT HAVE A PROBLEM INTERNAL ON THE ICE MAKER BEST YOU GET A TECHNICIAN TO CHECK THAT.GOOD LUCK.MOHAMED
Sep 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
this is from another post i did but will cover you too your ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure yuo hold the plastic insulation so you don't get bit if the ice maker starts cycleing remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didnt fill replace the water valves if the icemaker doesnt cycle and yuo may have to kinda twistm the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jan 19, 2008 | KitchenAid KSRP25FN Side by Side...
Frigedair refrigator
My GE Side by Side refrigerator is about ten years old. the refrigerator side stopped working and is warm. The ice box side is cool but is not as cold as it usually operates.
Nov 07, 2007 | Whirlpool GD5SHAX Side by Side...
Aug 21, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
26 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
