Question about ASUS Tablets & eReaders
How do I turn on my touch pad light for asus G1s?
Reset ep121 asus tablet
http://www.technipages.com/how-to-soft-and-hard-reset-asus-eee-pad-transformer
Dec 04, 2015 | ASUS Eee Slate EP121 Touch
I have a crack on my asus tablet what should I do?
Crack+touch screen not working usually means broken digitizer, which means replacement screen. Usually cost prohibitive in something like the Memo series.
Mar 03, 2015 | ASUS MeMO Pad HD 7
I have a asus memo pad hd 7 me137x and my problem is that my touch screen is not partly working at all i there a way that i can fix it
i do have the same problem like my touch stopped working. and nothing really happened to the tablet and i am sure that it needs a new software so could any one tell me hot to flash a new firmware in asus me137x without root
Sep 23, 2014 | Tablets & eReaders
The touch pad on my 10.1 inch asus memo pad doesn't work
Hoe long have you had this tablet? The fix may not be one that can be repaired without opening the case. But I would try a factory reset first.
With this problem, you will need to contact Asus.
Sep 17, 2014 | ASUS MeMo Pad Smart 10
How to change top glass of me173x?
Asus MemoPad ME172V Take Apart and Reassembly Nothing Left This is the basic way its done.If you'd like i can do its for you.Call 225-290-5733
May 25, 2014 | ASUS MeMO Pad HD 7 ME173X-A1-WH 16 GB...
How to turn off predictive text from asus tranformer notebook?
To turn off predictive text, go to Settings - Language and Keyboard - Touch Input - Text Input - Prediction.
Then select On or Off - See more at: http://www.phonetipsandtricks.com/tips/samsung-galaxy-note/turn-off-predictive-text-38/#sthash.MPTR2fvE.dpuf
May 08, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
No sound on my asus transformer eee pad
I have an Asus Transformer EeePad also. I have a sound control button on the outside edge, upper left. Press the top part of it for up, and the bottom end of the button for down.
Otherwise, go to "settings" "sound" "volumes" . There should be a list of 3 items, "Music,video games etc" "Notifications" "Alarms". Each one has a sliding scale of sound. You can slide the volume of each one individually with your finger, then touch "OK". I hope this is of some use to you.
Mar 14, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
ASUS pad tablet wont turn on
hi celeste.
see if this link will help you sort it out.
ASUS pad tablet wont turn on Google Search
Nov 02, 2017 | Tablets & eReaders
How can i move my curser and completely stop?
on the mouse pad sometimes you will find a little touch button that immobilses the pad
Aug 03, 2010 | ASUS R1E-B1 Tablet PC
Tablets & eReaders Logo
41 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
