Question about Canon MP560 All-In-One InkJet Printer
ScanGear Error ScanGear brings up an error of 2 145 13, and checked that everything was fine, but scangear refuses to scan any of my documents.
4 Suggested Answers
SOURCE: Scangear Error
i think this problem come with windows xp update!
when u started to see this messege?
Posted on Jun 03, 2009
venexcsd
  • 1185 Answers
SOURCE: How to get ScanGear Software?
www.canon.usa it is part of the original installation CD for your scanner
Posted on Jul 06, 2009
SOURCE: i have a canon leser mf4360 printer. i installed
step1 Install Printer drivers, after that install presto page manager....after it install ----- color network scan gear......after install it go to scan gear tool click on discover your printer IP address will appear in list then select that IP address .....exit form the tab.
go to the presto page manager............go to file ..select aquire image data press ok ok..then click on scan button....It will work
Posted on May 09, 2011
Hi, I have Canon iR2018 connected on network. I want to know if it is possible to use it for scanning documents with multiple pages (eg. books) and store the scanned documents on a PC connected in the...
you need to install colour network scangear. Its available in the driver cd or you can download it from canon's site. Install the driver. select scangear tool from programs. put the printer in scanner mode then click search. the scanner and ip address will be listed.click it and then click select. then exit from the window. Color network scangear is available for windows only. Now for scanning you need
(i) windows word 2007
insert>picture>from scanner/camera and you will get scanning window.
(ii)in earlier version of ms office
there will be office document scanning tool
select scanner
you will get scanner window
(iii) photoshop
file> import
you will have to select scanner
then you will get the window for scanning.
(iv) word 2008
clip manager> insert clip
select custom insert
Apr 14, 2011 | Office Equipment & Supplies
Unable to scan a document
Ok have you installed ScanGear? and ALL the right drivers from the DVD or web site? You MUST install BOTH Printer Z& Scanner Drivers and ScanGear, you use ScanGear to scan with...it will work if drivers are installed correctly. Did you install as Administrator? If a 64 bit system,have you disabled driver signing at bootup press F8 and do so if not. Below is a link for the up-to-date manual. http://www.retrevo.com/support/Canon-MP470-Multifunction-Printers-manual/id/3124ci176/t/2/
Anyway here is a link for a scanning package it doesn't use any driver, you can use this to check functionality of scanner.
www.hamrick.com/
Mar 04, 2010 | Office Equipment & Supplies
Scanner is scanning everything in with inverted colours, is this a setting somewhere in the ToolBox It was working but I think one of the settings may have been changed. Thanks
It seems that the Source is improperly set in the ScanGear software interface. From the ScanGear screen (where you Preview and Scan your documents/film), click on the tab labeled 'Advanced Mode' at the top. Under 'Input Settings', in the box next to 'Select Source', choose the type of film you are scanning (usually Color Negative Film if you are scanning 35mm negatives).
Feb 10, 2010 | Canon CanoScan 4400f MultiFunction Color...
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon ScanGear CS driver error Code: 2,252,0 - Can't preview Actually I have the Canon CanoScan LiDE 80 Flatbed Scanner - but this wasn't presented as an option, so I thought I'd try the nearest...
Canon ScanGear CS driver error Code: 2,252,0. Error when trying to Preview scan using ScanGear in your program, e.g. Word, PhotoShop...
I had the same problem, Canon Technical were clueless on this error code. Yes the problem occured when trying to preview first however I could scan but without any preview, pointless really.
I have fixed it for Windows Xp SP3, Canon Lide 80. To Fix:
You need to download the latest ScanGear driver and Deldrv.exe from the canon website. You don't need the Toolbox, http://software.canon-europe.com/
It would help if you have Tuneup 2009 (even Trail version) for the later parts of this fix: http://www.tune-up.com/download/ just click download, you don't need to give them your email address.
1. Save these on C:
2. Remove the USB cable from your scanner - make sure it is unplugged.
3. Run Deldrv.exe, select your scanner and uninstall.
4. Now you will need to go into 'C:/WINDOWS/TWAIN_32' folder; you must remove anything in this folder - safest thing to do is CUT any items and paste them on the C: or personal folder.
5. Now the register parts - you need to purge your registry of any left over values. I found out after several attempts that this final step fixed the problem for me.
Basically through Windows XP Regedit or TuneUp Reg Editor search the ENTIRE registry for first 'ScanGear', second, 'Canon' and third if you have installed previously, 'Canon Toolbox'. Find any entries relating to any Canon scanner software and delete them. I only found around 6 or 7 entries to remove.
6. If you have TuneUp run '1-Click maintence' (correct problems) and afterwards run the 'Register defragger'. Restart.
7. On the next bootup your register should be optimised. Ok, disable any Anti-virus software.
8. Run the scangear setup winzip file you saved on C:. * it will extract a folder to C:. If get an error with the extraction, try running it anywhere else except C drive. Alternatively if you have WinRar, right click and manual extract contents. The scangear setup winzip file/folder (called lide80vst7250a_xpen) only contained a readme and setupSG.exe.
9. You must run the setupSG inside this folder. And you're done. Enable your anti-virus.
9. Now connect USB to scanner, Windows should pick it up. Open Word or PhotoShop > run the scangear program to preview.
10. Done! It worked my end.
Please let me know if this helped you.
Mar 14, 2009 | Canon CanoScan LiDE 70 Flatbed Scanner
I have no manual and I need to figure out how to scan on this machine. Canon Imagerunner 50001.
Download the network scangear from the canon web site.
Install the scangear on all the computers you want to scan to.
On the scangear tool there is a discover icon,click that icon and wait till the ir 5000 is picked up by the network.Select the machine in the scangear tool.Now you will be able to scan to mirosoft word and exel like you normally do with a scanner.
If the scangear tool was unable to discover the machine,the network settings of the IR must be checked.
Hope this help.
Mar 09, 2009 | Canon imageRUNNER 5000 Copier
Scangear Error
Nov 30, 2008 | Canon MP610 Photo All-In-One Printer
Canon ScanGear Ir - how to set defaults?
ScanGear won't run under Vista. The scanner works with other programs. (Twain works) ScanGear fails and Vista closes it.
Don
quantm@localnet.com
Sep 21, 2007 | Canon imageRUNNER 1023N Black and White...
Canon MP560 All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
