Question about Denon AVR-3300 Receiver
Can i hook up a power amp to my denon avr-3300 with out a pre-amp
  • 757 Answers
Yes. Your receiver has the required pre-out connection terminals needed to go to an external amplifier. That would make your receiver operate as the pre-amp/processor.
Posted on Feb 22, 2012
  • 54 Answers
SOURCE: No Audio Output
OK.....there was a strange thing with this receiver......make sure that you are not on " headphones only ". Had a customer with the same problem. As for the fan, it doesnt run constantly. It only runs when the amp is hot enought to require extra cooling.....HOWEVER....there was a problem with the fans on these units, so much so, that Denon released a modification for the 3300 including a new fan and some upgraded circuitry.
If the unit is not flasning " protection ", or " overload".....you should be OK., however I would spend a few bucks and get the fan mod installed.....these are good sounding units and ecen though it does not have Dolby PL II, and DTS-ES, I have owned a couple of them and find that they sound better than most new ones. Get out your owners manual and look in the headphone section. If memory serves me well, there is even a way to do it with the remote. Good luck.... Rob
Posted on Apr 22, 2008
mattvierra
  • 74 Answers
SOURCE: Denon receiver AVR-3300: Unstable source selection
Very important you have run system set up menu it configures your receiver with inputs analog or digital,speaker size,input,room correction etc Different input modes can be selected for the different input sources.
The selected input modes for the separate input sources are stored in
the memory.
q AUTO (auto mode)
In this mode, the types of signals being input to the digital and
analog input jacks for the selected input source are detected and
the program in the AVR-3300’s surround decoder is selected
automatically upon playback. This mode can be selected for all
input sources other than PHONO, MD/TAPE and TUNER.
The presence or absence of digital signals is detected, the signals
input to the digital input jacks are identified and decoding and
playback are performed automatically in DTS, Dolby Digital or PCM
(2 channel stereo) format. If no digital signal is being input, the
analog input jacks are selected.
w PCM (exclusive PCM signal playback mode)
Decoding and playback are only performed when PCM signals are
being input.
e DTS (exclusive DTS signal playback mode)
Decoding and playback are only performed when DTS signals are
being input.
r ANALOG (exclusive analog audio signal playback mode)
The signals input to the analog input jacks are decoded and played.
t EXT. IN (external decoder input jack selection mode)
The signals being input to the external decoder input jacks are
played without passing through the surround circuitry Your remote is searching for inputs because you did not properly run system set up!!! Here is a link to your manual [PDF] AVR-3300/1 3.3E*
Posted on Jul 22, 2009
  • 8 Answers
SOURCE: I just need to find a schematic for a Denon
Does this help?
http://www.usa.denon.com/avr3300_technotes.pdf
Posted on Dec 04, 2009
  • 137 Answers
SOURCE: i have a denon avr 2802. the remote powers the
Try doing a factory reset by turning off main power switch.hold down speaker a and b buttons while turning on main power switch ,display will flash 3 time s then release buttons,this then returns unit to factory default settings.
Posted on Apr 14, 2010
  • 163 Answers
SOURCE: how to do a hard reset on a denon avr 3300
Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet.
Posted on Oct 17, 2010
Testimonial: "worked like a charm thanks for the help"
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
Can i hook up two subwoofers to a denon avr 1907
Sure, just get an RCA splitter and share the Sub Pre-Out with the two self-powered subs or one amp powering two of them.
http://www.retrevo.com/support/Denon-AVR-1907-Receivers-manual/id/696ci072/t/2/
Dec 28, 2010 | Denon AVR-1907 Receiver
Power amp 2 channel connection to Denon a/v amp
You don't mention which AR amp we're talking about.
I think you're trying to say you want to know where to extract the front channels from the Denon to feed the AR amp. Right?
That would be an output on the Denon to an input on the AR.
Basically, take an RCA cable pair from the Denon's Pre Out F & L and connect them to the (presumed) L & R inputs on the unnamed amp.
Set the AR amp at a reasonably high volume (if it has a volume knob) and leave it alone. Run through the speaker level adjustments on the Denon to match the Front to everything else and it will control the volume going forward.
May 28, 2010 | Denon AVR-3300 Receiver
Denon AVR-3300 component channel switch burnout?
hi there, i don't have a solution unfortuantely, but i may have the same problem. I have a denon 2802 av receiver, i bought it second hand and I can't seem to get the component video in / out working. Are you supposed to just plug it in and it works? Because I can't find any buttons or settings to select component in / out as my input / output sources?
Nov 12, 2009 | Denon AVR-3300 Receiver
I have a buzz / static that appears for the first 15 minutes.
Hi...
I just opened up an AVR3300..It's trouble is that it goes into stndby
at once.
The BIG power supply caps are VERY swelled at the top.
That would be my informed view on why it's bad.
I suggest you look at that being your possible trouble too.
Scott in Vermont
Jun 22, 2009 | Denon AVR-3300 Receiver
Denon 3300 Fan Workaround?
the preamp section will not generate a great deal of heat. Try it and see...leave the amp running with signal going through it and the prein-out jumpers removed and see what noises it makes over time
Nov 22, 2007 | Audio Players & Recorders
The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Nov 19, 2007 | Denon AVR-3300 Receiver
Denon AVR-3300 Receiver Logo
383 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
