Question about GE WBSR3140DW Top Load Washer
Whdsr316g1ww I need a diagram of inside the timer box.
  • 61 Answers
Ther shoot be 1 in the concel try to open it and look inside ge is good to put 1 ther ther not. the only 1 the can get on is ge try caling the the # is 800-gecears
Posted on Feb 22, 2012
I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
motor swap>?
Problem with 1993 Toyota Supra I have isuzu elf fire engine local mentinence department cut down the ecc box timer that's why i need electric diagram.
Jan 17, 2014 | 1993 Toyota Supra
Replying to Richaed Roth - Amana ARB2557CSR Defrost timer. diagram from online source shows timer on the inside of the frig box near the lights. I've not done anything yet to verify te location a
OK, you can open the cover. Here is the part if you need it.
Here is a diagram if you should also need it. It is number 12 on the diagram. Let me know if you need anything further. I forgot what the original question was.
Nov 07, 2012 | Amana Refrigerators
My GE whdsr316g1ww will freezes during the 'Cottons' cycle
please see the next step and use the common sense: God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub
Aug 01, 2012 | GE WBSR3140DW Top Load Washer
I need help to install pool pump to mechanical intermatic timer switch GE to replace the digital control.
Question is not clear.
Add a comment with missing information for exact wiring diagrams.
Voltage is not known.
Timer model numbers are not known.
You have two timers.
You are replacing unknown electronic timer with unknown mechanical timer.
Intermatic timers and GE timers are different companies, and each makes many different timers
Each box timer has identification on inside of timer door.
Open following links to help identify timer and see wiring diagrams.
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 14, 2011 | Intermatic T104 24h 208-277v Mechanical...
Lost wiring instructions for my woods water heater timer. What wires attach to bus bar
Timer model is usually located inside the door panel:
1) Open following link to access manual with wiring diagrams.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Boxtype
2) Example manual shows different wiring diagrams:
http://waterheatertimer.org/pdf/Woods-59396-59399-manual.pdf
If you have timer with 8 terminals, and ordinary 240V water heater, then use diagram on bottom right.
3) Woods timers are wired identically to GE 15207, except your model might not have dip switches.
http://waterheatertimer.org/How-to-wire-GE-15207-timer.html
4) Busbar usually refers to a long metal bar where many wires connect to same pole. For example neutral busbar inside breaker box has 20 or 30 wires connected to it, and all are connected to Neutral wire from power pole.
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
5) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Kitchen Ranges
Need wiring photo
You posted under Intermatic T101R raintight 120Volt box timer.
Drawing of T101 wiring appears on following link
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
If you have a different timer, look at information on inside of timer door
Also open following link to help narrow down your timer and see wiring diagrams for each of timers shown:
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 07, 2011 | Solar Intermatic T101r 120v 40amp Timer...
I need to rewire this switch into a light for an aquarium..can you supply wiring diagram
You posted under Intermatic 240Volt T-1906 box-type timer:
Look at model number on inside of timer door.
If this is not your timer, then link below doesn't apply.
Wiring diagram appears on following link:
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
It seems unlikely you have expensive 240Volt box timer for aquarium light.
So add a comment with clear description of your timer/switch.
If you have wall switch instead of timer, please describe the device, and screw colors on device, and wire colors inside box.
For a price, expert speaks with you over phone while you work on your do-it-yourself project.
Jan 17, 2011 | RTO Intermatic T1906 Elec Mechanic Timer...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
hi, reset the printer.
open th right door,without paper then close the door
it work
thank you
May 17, 2009 | General Electric WHDSR316G Top Load Washer
GE WBSR3140DW Top Load Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
