Question about Garden
Where is the air cleaner 4hp john deere trs21 snow thrower
Ijust see a spigot shaped air inlet directly into carburetor,Is something missing here??
4 Suggested Answers
  • 3911 Answers
SOURCE: Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Posted on Oct 15, 2009
  • 3911 Answers
SOURCE: Our church came into possesion of a John Deere GT
Well what I would suggest is either pray for divine guidance or do a google search. I got a simplicity mower with no instructions and my first idea was to google it. Darned if i did not get a link to the manufacturer's website and they have free downloads of manuals and illustrated parts breakdowns.
Posted on Nov 23, 2010
  • 123 Answers
SOURCE: John Deere G049K Snow Thrower Service Repair
An older snowthrower will make some noise, but it depends on what kind of noise you are hearing. A "growl" is not common and can indicate the gearbox is low of oil or the oil needs to be changed. The gearbox is mounted on the back of the snowthrower and there will be a dipstick on top. There should be oil on the dipstick, and it should be kind of thick. Proper gear lube is 80-90, and should be a gold color. Also check to make sure the auger bearings are not going bad. You can grab ahold of the auger while the machine is off and try to wiggle it. If it moves at all the bearings will have to be replaced. Start there and let me know if you need anything else, Daniel.
Posted on Nov 04, 2011
John Deere LT 155, why are small amounts of oil dripping into the carburetor air intake thru he oil breather hose connected to that air intake chamber
the breather hose is the means of allowing the compression by pass gasses to not build up pressure in the sump and it exits into the air inlet system near the air cleaner
for oil to be dripping there indicates
1--excessive oil in the sump
2-- worn rings allowing excessive blow by and boiling the sump oil
3-- incorrect oil used in the sump ( too thin) try a 30w -50 grade
Dec 18, 2016 | John Deere Garden
What colour wires go to the coil on a 726 snowblower
OK the wire on a coil is to shut off motor when grounded, so if you don't hook it up it will not shut off when you try. That wire goes to throttle linkage so when you slow engine speed to minimum it shuts engine off. Most snow blowers that have the red safety key in shield have that same wire slit from the throttle so if that malfunctions you still have a safety shut down.
May 22, 2014 | John Deere Tecumseh Snowblower Heater 726...
Carberater for my snow thrower isn't getting gas
The carburetor could be clogged. Try spraying some carb cleaner into the engine to see if it starts. If it does, then some part of the carb may have varnish clogging some of the ports.
Jan 30, 2014 | Craftsman 24" 208cc Dual-Stage Snow...
TRS21 cloggs in the chute
I have the exact same problem. Also it won't clog so easily if the snow is deeper because the auger moves more snow through (or if I run with it.) It seems to me that the auger should be as close as possible to the scraper bar without causing any friction. Do you think that distance adjustable, or would new paddles on the auger close the gap sufficiently?
Dec 26, 2012 | John Deere Trs21 Rubber Auger Paddle Set...
Our church came into possesion of a John Deere GT 262 with several attachments. Unfortunately we don't have the instructions for attaching the snow thrower. There seems to be a couple of parts missing. ...
Nov 23, 2010 | John Deere Garden
John deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Oct 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Sep 10, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
