Alex builds 3 legged stools and 4 legged tables. Last month he used 72 legs to build 3 more stools than tables. How many stools and how many tables did he build
    Sergeant:
  • 192 Answers
T = # of tables
s = # of stools
4t+3(t+3) = 72
4t+3t+9=72
7t=63
t=9
s=t+3
s=9+3
s=12
Posted on Feb 21, 2012
I have a model 875.498601 workshop stool need to know how to remove the floor protector on bottom of the stools leg, have to install another one
The plastic foot is adjustable snd covers a bolt that is threaded into an insert in bottom of leg. Should be able to unscrew it by hand (if new), or use a pair of channel locks
Jan 05, 2017 | Furniture
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
What type of bar stool is best for overweight individuals?
The best type of bar stool for someone who is overweight to sit in is a floor mounted stool. This type of stool is securely attached with bolts to the floor beneath it, ensuring better support and stability. If you don't want to bolt down your stools, your next best option is to get a four-legged stool. Four-leg bar stools disperse the weight of the person sitting on them evenly. On the downside, four-leg stools have a higher risk of tipping over.
Jul 24, 2012 | Furniture
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
What can be done with a scoll saw, table legs?, what uses is the scroll saw for
Scroll saws use a small thin blade that runs up and down very fast. It is used to cut curved designs out of flat wood. Table legs are made on a lathe, it spins a square or round piece of wood to make legs, baseball bats.
Mar 01, 2011 | Garden
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
I need assembly directions for evenflo exersaucer triple fun.
1. Remove toys and seat from the exersaucer.
2. Fold exersaucer, but do not let the tray lock to the base. With exersaucer flat on the floor, twist each leg assembly (B) fully clockwise until it stops. Fully depress one of the pedestal locking tabs (C) then push on the leg assembly (B); leg will partially fold. Repeat this for all four legs. After pressing the fourth pedestal locking tab (C), the Exersaucer will fold with the tray (D) rotating toward the base (E). Make sure all four tray locks. (F) are locked onto the base before trying to carry exersaucer.
3. Place your fingers beneath the legs (A) push upward to disconnect the leg assemblies from the pedestals (B). Repeat for all 4 leg assemblies.
4. After all four legs have been disconnected from the pedestals, remove tray assembly (C) from the base (D).
5. Turn tray (C) upside down and remove both end caps (E) from beneath.
6. Squeeze both locking tabs (F) on each side of the tray to disconnect and seperate the tray halves (C). 7. Connect tray halves (C) to form activity table.
8. Rotate leg assemblies (A) fully clockwise until they lock into postition. Make sure all four legs lock (G) are locked properly into the uper leg pedestal (H). Also make sure all four leg locks (I) are sticking out past the edge of the tray.
9. Turn table over and install two end caps (E). Make sure both end caps lock into place. NOTE: one end cap installs from above and the other installs from below.
10. Install toys on activity table. If desired, adjust table to the appropriate height for your child. IMPORTANT: NEVER use stage 3 without end caps!
Mar 20, 2009 | Evenflo Exersaucer Triple Fun Active...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
