Question about Element Electronics Televison & Video
Adjusting color on element lcd tv
Color adjustment
  • 280 Answers
SOURCE: What is the best technic to adjust the colors on my TV
The easiest way is ... from the menu set all video to default. if there is nothing wrong with the set it should look normal.
Posted on May 23, 2008
  • 11 Answers
SOURCE: hitachi 50v500a high definition tv
I had whole redish/pinkish screen on my 50v500 starting a few days ago, then I read through each of the threads on this site for the samilar problems on my model. I found TVtechmaniac's solution (pasted below) solved my problem. Thank you TVtechmaniac!
Enter the I2C Service Menu, be sure the power is OFF.
1. On the front control panel, press and hold the INPUT button.
2. Then press the POWER button for two seconds.
3. You may keep the INPUT button depressed until you see the OSD with the Service Menu displayed.
4. If you don't see the service menu, please repeat Process making sure you wait until the Power blinking LED stops.
5. Execute the Memory Initialize operation after the adjustment values have been written on a sheet of paper. Highlight “MEMORY INTI”, arrow to the right and hold the button to the right (approx 5 sec.) until a check mark appears in the box. This activates the Memory Initialization.
6. After the Memory initialize operation has finished (10~15 sec, the channel will revert to CH 3.) the pink image symptom should be fixed.
7. Write back the adjustment values from your notes to their respective adjustment parameters in the adjustment mode. (In other words, set the Data Values back to the the Data values written down before the Memory Initialization procedure). NOTE: Make sure the SELECT Button is pressed on remote after every change to the values. Failure to do so will result in the data values not being changed.
8. Exit I2C menu. Press exit repeatedly until you go back to the normal picture.
9. Turn the set off-on and Confirm the picture remains in a good condition.
BE SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS
Posted on Aug 31, 2008
  • 8 Answers
SOURCE: COLOR TV SETTINGS
get a thx optimizer disc and put it in your dvd and set..baby set...
Posted on May 12, 2009
gsalmen
  • 77 Answers
SOURCE: I have a 50" LG Plasma that has lost color only with the tv
the main total assy might be the problem. it controls color, pix size and such.
Posted on Jul 09, 2009
toddthetvmd
  • 101 Answers
SOURCE: Dynex 37" LCD TV bad color
You have a bad LCD control board going bad,Color getting floresent? Or pixely? esp. when you have it on for a bit. Common prop. But finding parts is a prob.
They are no longer in buis. Try Shop Jimmy,or even Ebay. Encompass does not have any. Runs about 40-60.
Posted on Oct 26, 2009
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
How to fix emerson tv color caused by a power surge
If yo cannot adjust the color through the TV's menu color adjusting option, then the surge might have damaged it.
Oct 21, 2014 | Emerson LC320EMX 32 in. LCD HDTV
How do i adjust the color on an element tv
you will need the remote that came with the tv
in the menu it has limited control of colors an color temp.
Sep 25, 2014 | Element Electronics FLX3210 32 in. LCD TV
How do you adjust the tint on the element tv?
On NTSC system tint option available. Use NTSC system TV channel and adjust the tint of colors. This option is not available in PAL / Se cam standard.
Jun 11, 2014 | Element Televison & Video
Can't adjust tint in 50 HD Digital LCD TV Element
I called Element TV they said the Tint adjustment/controls on most Digital Element TVs are programmed for "Non adjustment"with digital signals:
On Large Element TVs , the "Tint" controls are used only for Analog Video and for NTSC viewing, but the controls are inoperative or blanked-out when watching PAL or SECAM digital signals (my is HDMI directly from Digital cable box).
Dec 02, 2012 | Element Televison & Video
HOW TO ADJUST THE COLOR ON A LCD T.V
My color adjustments are on the menu for my LCD tv.
Sep 07, 2012 | Samsung Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
My tv only has yellow green and blue. How do i get full color back
go into the menu there shoul be picture setting or contrast/color go into it there are adjustments there
Dec 11, 2010 | Element ELC-HS321 32 in. LCD TV
Trying to adjust my Philips TV's Custom Color Temperature
Philips 32PFL3403/12 problem with colours, after 1 hour working: starts to mix colours.
Feb 20, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Televison & Video Logo
180 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
