Question about IBM ThinkPad T41 Notebook
Replacing an IBM T41 LCD Assembly
I read your post but could also use a few pictures to help me along.
Do you have any you can send?
Thanks
  • IBM Master
  • 4,338 Answers
Here is the service manual for step by step replacement: Under FRU replacement.
http://mbs.maine.edu/mbs/public/software/manual/ibm%20T40T40p,%20T41T41p,%20T42T42p/39t6192_01.pdf
This is the parent directory: double click on 39t6192_01.pdf :
Hope this helps,
If I could be of further assistance, let me know.
If not, please rate this.
Joe
Posted on Nov 20, 2008
IBM Thinkpad T41 beep sound on system startup
Here are the beep codes for the Thinkpad:" Continuous beeping System board failure One beep; Unreadable, blank or flashing LCD LCD connector problem; LCD backlight inverter failure; video adapter faulty; LCD assembly faulty; System board failure; power supply failure One beep; Message "Unable to access boot source" Boot device failure; system board failure One long, two short beeps System board failure; Video adapter problem; LCD assembly failure One long, four short beeps Low battery voltage One beep every second Low battery voltage Two short beeps with error codes POST error message Two short beeps System board failure.
Dec 26, 2012 | Dell Optiplex GX620 Pentium 4 3.4GHz (Open...
IBM T41
is the power supply fan working?
Sep 22, 2008 | BenQ FP731 17" LCD Monitor
2 X IBM T41 laptops, both with extremely dim displays. I'm guessing the inverter has gone, any thoughts? Any availability ideas for replacements for either inverter, ot complete LCD assy, including...
When the invertors fail, it is common to be completely dead not showing a little light.
Maybe they have both failed but I would check the power save settings first.
Hope that helps.
Feb 25, 2011 | IBM ThinkPad T41 Notebook
RE: How do I replace the LCD screen hinge on my IBM T41
here is the manual from IBM http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-46464
Sep 17, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T41 boot-up problem
Hello, enter BIOS (by pressing "Delete")and find there restore default. If you drop it you need check inside laptop of connections components. Check Cpu or Ram.
Sep 09, 2008 | IBM ThinkPad T41 Notebook
IBM T41 No power
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Installing a pc computer power supply
Once no power supply is installed into the computer, place the new power supply into the computer and screw the screws into the back of the power supply.
POST troubleshooting steps. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T41 Notebook
IBM T41 Hinge Replacement
Repair4Laptop: Repairing of Laptop and Notebook LCD Displays IBM ThinkPad T41: Screen inverter replacement guide, explaining how to fix a laptop backlight problem. ... Samsung X10: (An illustrated display hinge replacement guide)
Good Luck ...........Please dont for get to Vote, Thank You.
Dec 18, 2007 | IBM ThinkPad T41 Notebook
How do I replace the LCD screen hinge on my IBM T41?
I'm sure you could get these hinges from IBM, but no idea as to their cost. They are available on e-bay for $8-$35 (depending on whether you want 1 or a set) plus $8-$10 shipping.
As far as replacement. You will have to remove the Top cover assembly from the base of the PC. If you need help with that, just let me know and I'll talk you through that.
To replace the hinge, you will have to disassemble the Top cover assembly.The screws that you will need to remove are covered by small black adhesive covers. There are 3 round ones along the bottom of the bezel, 2 square ones up at the top of the bezel (to the left of the white LED keyboard light, and 6 (trapezoidal shaped) on the outside of the cover (3 on each side). Carefully remove those covers and the screws that are under the covers. Keep track of where the screws should go back in.
The actual bezel is held into the top cover with some internal snaps. Start at one of the corners, run a knife blade along the seam (between the cover and bezel) and you will hear each fastener "snap" as you slide the blade past it. Once the bezel is loose, lift it off of the LDC screen. There is one additional screw that is located up in the upper right hand corner. That one will need to be removed, also.
Gently lift the right hand side of the LCD assembly a couple of inches and place something of appropriate size to hold it in the raised position. You will see 2 additional screws that hold the hinge to the LCD assemble. Remove those and the old hinge will come right off.
Position the new hinge and replace the two screws that you had just removed. Reverse the removal sequence to reassemble the display.
Before you start snapping the bezel back into place, check to make sure that the two cover catches (those hook things, up at the top of the LCD assembly) are both operational. The link going to the left hand one tends to easily fall off.
This procedure should take in the neighborhood of 45 minutes to an hour.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thanks you, and have a super day!
Ron-
Nov 15, 2007 | IBM ThinkPad T41 Notebook
IBM ThinkPad T41 Notebook Logo
793 people viewed this question
Top IBM Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
