Question about Transcend (589307) Media
Write protected flash drive
My usb flash drive shows that it is write protected when i tried to format it.
how i can solve this problem?
  • Anonymous Dec 27, 2008
    i have Transcend Jetflash drive, i can't save anything in it or delet because it says that it is write protected. i tried the format but it not working becuse it is write protected,even i used "JetFlash Recovery Tool" it didn't work
    helppppppppppppppppppppp
  • Anonymous Dec 31, 2008
    GOOGLED THIS PROBLEM DONT SEEM TO HAVE MUCH INFO ON IT BASICALLY OUR FLASH DRIVES ARE SCREWED
Posted on Nov 12, 2008
I have TRANSCEND D33193 when i try to format, I have TRANSCEND D33193 when i try to format, or delete files from it, it shows YOUR DEVICE IS WRITE PROTECTED!
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Jan 14, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Memorex USB flash drive is write protected
t seems that your flash drive has some bad sectors since normally that's the error message you get when that happens, try to format your drive under disk management.
Note: your files will be erased if you format your flash drive.
If formatting your flash drive does not solve your problem I will advise you to contact Memorex technical support for better assistance, you can contact them at 1-877-363-6673
May 19, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
Cannot format diskrive because it is write protected
first open control panel then open computer management and than disk management than right click on pendrive option and format it
Jan 10, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
File allocation showing 64.0GB, Not formating
If you inspect the Flash drive, you will see a little sliding switch on it. Slide the switch to the other side. Now, try inserting the Flash Drive and you will have write access.
Jun 28, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have 1 gb iball usb flash drive & it is not formatting
Is there a write protect switch on the drive?
In Windows XP, right click on "My Computer", choose manage. Go to Disk Management and find the drive in question. right click on the drive for more formatting options.
Jun 21, 2009 | Computers & Internet
Unable to format the cruser pendrive
Far too often these little things have an almost invisible read/write protect button on them. Look carefully, over the entire surface of the USB Flash Drive. You might have this switch turned to Write Protect, which means there is nothing you can do, until you turn it the other way, and allow the device to be written to.
Cheers!
-a.
May 22, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Jan 30, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
PEN Drive error
right click on my computer after inserting the pen drive in usb, click on manage and select disk managment from left pan, you can format your pen drive by right clicking on it
Oct 24, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Doesn;t taking large files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 19, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to remove write protect from pen drive
I OWN A TRANSCEND pen drive of 8gb when i try to copy or format the command it shows is "cannot create,remove the write protected"what shall i do .the pen drive is very new
Jan 12, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Transcend (589307) Media Logo
421 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
