Question about HP Computers & Internet
Hp proliant ml150 g5 8 beep codes
Proliant ml150 g5 8 beep codes
SOURCE: From where I can get LAN Driver for HP Proliant
Click here
Click on above link and select your model and download network driver.
Let me know if you need further assistance.
Thanks.
Posted on Oct 28, 2009
Fredinot
  • 96 Answers
SOURCE: why I can't boot from DVD
You must have a bootable files in a DVD where system files are usefull as bootup system.
Posted on Mar 17, 2010
  • 166 Answers
SOURCE: Hard disk not found message coming while
Save any critical or important files. Even if this is an secondary hard drive installation.
Turn off the power and unplug the PC from the outlet. Also, unplug all external connections to the Windows PC. Be sure to touch something metal to ground the user. Static electrical shocks can damage a PC.
Open the PC housing and determine the placement of the hard drive. Generally computers come with a latch that, when pressed, opens the housing. Make certain the space necessary for the hard drive is available. Usually the drive bays are in the front of the PC near the CD or DVD drives.
Make sure the IDE jumpers are set correctly. If the hard drive is the primary drive then set the jumpers to "Master" mode. If the hard drive is the secondary drive then set the jumpers to "Slave" mode. Please consult the hard drive's manual for the proper jumper setting for each mode. Another possibility--if there are two hard drive, set both drives to "Cable select" mode and the Windows PC will choose which one to make "Master" and "Slave."
5
Mount the hard drive in the available internal slot. The drive is sometimes mounted with four screws to the drive bay. Some internal drives have a rail that slides into the open bay. Look at the other devices to determine which mounting option is available in the specific computer.
6
Connect the hard drive cables to the Windows PC. Connect the power supply connector to the available cable. Next, connect the data cable to the available connector. The internal data cable usually has a red stripe to make identification easier.
7
Close the housing and reconnect the external power supply. Plug the external cables back into the computer and reconnect to the power supply.
8
Configure the BIOS. The BIOS (Basic Input/Output System) is accessible during computer start-up. To access the BIOS consult the computer manual to find out with which key press during start-up. Most often, the key is F8. Once in the BIOS change the hard drive setting to "Auto detect." When finished, exit the BIOS and allow the start-up to continue.
9
Format and partition the Windows PC hard drive. Select "Start" from the operating system menu. Choose "Control panel" from the start menu. Next click on "Administrative tools". From the administrative tools menu choose the "Computer management" icon and finally "Disk management." Choose the new hard drive and right click. Select "New partition" from the right click menu. Follow the on-screen option to partition and format the drive the drive.
10
Restart the computer and check the hard drive to ensure it is operating properly.
Posted on Feb 23, 2011
  • 24 Answers
SOURCE: i am unable to instal
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Posted on Feb 28, 2011
  • 43 Answers
You need to press F6 and load special drivers for your disk driver card
See which disk adapter your server has and get the drivers on a floppy disk
Put the disk into your computer before seutp, then click F6 when prompted
it will search your floppy drive for them
Posted on Mar 18, 2011
Hp proliant ml150 "two beeps"
HI
if you hear 2 beeps code and no logo or video comes on means you have a bad HDrive. If you have engough tech experience or know someone who can check this in the BIOS and see if your hard drive is listed and also if the ram shows up too. You might try this before you spend time taking your system apart.
Good Luck
Chadman
May 14, 2014 | HP Computers & Internet
ML150 powers on but no post
Motherboard is fried. Most probably. Replace motherboard.
Oct 11, 2012 | HP ProLiant ML150 G5 Server
HP Proliant ML150 G2 beep codes, 1 slow, 3 fast, then 3 fast, one slow
Google HP Smart Start. Download version needed. Unzip and burn. HP Management DVD is also available. It has Insight Manager.
Sep 13, 2012 | HP Compaq ProLiant ML150 G2 Server
HP PROLIANT SERVER gives continuos beep beep beep when logon windows appear and continues beeping after logging on
First check your keyboard it could be a sticky key, if not than the best would be to install the HP diagnostic tools, (CD supplied with the machine) or download from the HP website... Look in Windows event viewer to see if there's something wrong as well...
Jul 28, 2011 | HP ProLiant ML150 G5 Server
HP ML150 g5 dont star
1. try replacing thermal sensor
2. try replacing power supply
3. then systemboard last
Sep 24, 2009 | HP Compaq ProLiant ML110 G4 Server
HP ML150, blank display
Sounds like a system board or processor failure.
Apr 08, 2009 | HP Compaq ProLiant ML110 G4 Server
Hi support, Am Kennedy.I just wanted to know how i can get a VGA card for Hp Proliant ML150 and what are the costs. Thanks and kind Regards:
Hi there ,
In a HP ml150 you can install a PCI VGA card subject to availability.Normally it comes embeded on the motherboard .But if other devices are installed on the same PCI bus its efficenciay will be dgraded to the PCI VGA card.
Jan 09, 2009 | HP ProLiant ML150 G5 Server
HP Compaq ProLiant ML150 G3... Problem:
Hi ,
1) This server is a G3 , latest is G5 . It is outdated unsupported equipment.
2) Your continuous beeps on boot up with no video seems to indicate VGA card problem . Just put in another cheap VGA card and retest.
Good luck on solving your problems , hope I have helped you.
Jul 24, 2008 | HP Compaq ProLiant ML150 G3 Server
Computers & Internet Logo
915 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
