Question about Zanussi F1045W Front Load Washer
Machine will not empty or rinse
The machine is not rinsing out the clothes. It takes in water and appears to run as normal but then it does not drain out the water. I tried using an alternative wash program and it did not take in any water. I am not certain if the problem is that its not draining or its not spinning correctly.
  • 5 more comments
  • theaton56 Nov 04, 2007
    Mine makes this horrendous noise during the "drain cycle", I used the tube to drain the drum then opened the filter. At the back I noticed the rotor section (with the vanes) was lying to one side. It seems that it has seperated from the pump shaft. Trying to source a replacement pump is a nightmare.... no longer available apparantly.
    Any thoughts ??
    TH
  • devisubu Nov 19, 2007
    mine is ge washer.the problem is its not draining the water.i some of my daughter some socks had stuck in the machine.but i don't know how to fix it.can anyone help me please.
  • Mpush Dec 14, 2007
    I have a frigidare galaxy front load washer that will not empty the
    water in the rinse/spin mode. Also when trying to start a load in
    any cycle the washer will not dispense any new water. The belt is
    fine, and the unit seems to turn both directions, but there is a load
    humming sound coming from beneath the tub. I am not sure where to
    start in the repair process.
  • Anonymous Feb 21, 2008
    Water will not drain out at Spin Cycle. In fact when the water is still in it won't spin at all. However, if manually drained (by front Tube) & the spin cycle is run when the machine is empty, it will spin.
  • handymanedd May 24, 2008
    water wont drain
  • poppy1976 Aug 04, 2008
    machine completes wash programme as normal - taking in water and rinseing. however on final rinse and spin it simply stops and will not go any further. I can empty manually using the front filter. have tried several wash programmes but the same thing happens.
  • vinisammon Sep 06, 2008
    My zanussi will not drain or spin. I have emptyed out the water through the front panel and checked the filter, but it still wont spin. How do i go about taking off the drain hose to see if there is a blockage, i had a look but am a novice. Should i just go ahead and start unscrewing the screws around the drain hose?
    Vini
I have washer make of sears and been using last 5 years. But now the problem is washer works preety good but at the last cycle it does not spin to rinse . can you tell me how can I fix the problem.
Posted on Dec 15, 2007
    President:
  • 1,294 Answers
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Posted on Apr 13, 2007
I have a whirlpool washing machine fully automatic. Foe the past two days water was not pouring in the machine. Seems to be the failture of the solenoid valve.Further, when water poured inside manually,...
the drain pump may be blocked, machine wont fill if there is still some water in the system if it hasnt emptied properly. Remove the filter usualy under the panel at the front, and check for blockage and veryfy pump is running.
Jan 18, 2011 | Washing Machines
Wont adavace after wash cycle like its stuck replying back
Hi just read your posting. The problem appears to be your drain pump is either blocked or faulty.If you would like I can guide you throe the removal of the pump. The reason it does not reach full spin speed is there is still water under the bowl slowing it down.It is impossible to drain the machine by hand completely.Please reply If you require extra help on the pump removal.
Jun 07, 2010 | Fisher Paykel EcoSmart GWL15
Machine not taking the last fastest spin to drain the water.
the problem is that your machine is not emptying the water fast enough as the machine takes in a good deal more water on the rinse. clean the filter.
Feb 02, 2010 | Hoover Nextra HNWL 3126 Front Load Washer...
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Zanussi F1045W Front Load Washer Logo
386 people viewed this question
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
