Question about Intel Motherboard
M3plugin error on start up file m3plugin.dll
  • N Baker Dec 01, 2008
    Error at startup for C:\Progra~\MyWebsite\1.bin\M3Plugin.dll
Good morning
my m3plugin.dll file is missing. how can i reinstall it?
Posted on Feb 12, 2009
  • 71 Answers
AFAIK there's no such "good" program that will start an m3plugin.dll at startup.
Your system might have been infected by spyware.
If you don't have good antivirus/antispyware then you need to get one.
My recommendation if you try to find free solution : spybot search and destroy / AVG Free
To manually remove the message :
  1. Run Regedit
  2. Find "m3plugin.dll" (usually it will be in "RUN" or "RunOnce" Key)
  3. Delete the value of the key when you find it.
  4. Also check your Startup Folder (Start > All Programs / Programs > Startup
  5. Also check your Startup Configuration using "msconfig"
  • Start > Run > msconfig > enter/return
  • Go to "Startup" Tab
  • Find the "Command" that point to "m3plugin.dll" and clear the check mark
  • Apply > OK > Restart your computer
Rescan your whole computer using updated antivirus/antispyware.
Posted on Oct 27, 2008
4 Suggested Answers
colliewob
  • 781 Answers
SOURCE: m3plugin.dll
Uninstall program reinstall seem like the program has missing or corrupt files
Posted on Jul 27, 2008
  • 3 Answers
SOURCE: M3plugin.dll problem
try use spybot to scan...it is a spyware..
Posted on Aug 04, 2008
SOURCE: missing m3plugin.dll
hi,
http://www.fix-all-dll-errors.com/m3plugin.dll/
This site will definitely help u...
as I registered few dll's from this site...worked in my case :)
Posted on Jan 17, 2011
Error with M3PLUGIN.DLL
Click on start
select run
in the run box type msconfig
choose startup tab
and uncheck M3PLUGIN.DLL from the startup
Jun 18, 2009 | Microsoft Windows Vista Ultimate Edition
When i startup my laptop i get massage that i lost m3plugin
Windows errors related to m3plugin.dll?
If Windows is unable to run applications due to a .dll error, this .dll may be missing or you may have registry error. Such errors can heavily influence the performance of your PC. I strongly recommend that you run this free registry scan.
Here you can download m3plugin.dll free of charge. The file is compressed so you need an unzip software in order to use the file. We recommend you to read the tutorial how to unzip and install the files. Use the link below to start downloading m3plugin.dll.
arrow_w.gif Recommended: Fix m3plugin.dll Errors arrow_w.gif Enhance your PC-speed: Free Performance Scan arrow_w.gif File description: MyWebSearch Idle Monitor, v. 1.0.3.2 arrow_w.gif Filesize to download: 2.4 kb
download_icon.gif Click here to go to the download of m3plugin.dll
Jun 09, 2009 | Intel Motherboard
Iwve got an alert that i missed m3plugin.dll i found the dll file and copy it to the correct file according the path but now he say that i missing antry upf
Try to register the DLL file. Goto run type cmd. This will open the command prompt. Type regsvr32 c:\enter location of .dll file\m3plugin.dll and press enter. This will register the .dll file if that is the problem.
Dec 03, 2008 | Intel Motherboard
Missing m3plugin.dll
Hi ssponheim,
this is a common issue with the program. (MyWebSearch).
Try this. Right click once on the start button, (Apop-up window will open), slide up to Explorer & left click on it once. Right click once on the C: drive & left click Search. In the search top window type the name of the file: m3plugin.dll
Click search.
Windows will find the file. Right click once on the file m3plugin.dll listed in the right hand side of the window & left click Copy. Windows Explorer is still opened. Scroll down to the folder Program Files & left click the plus sign next to it. Program Files will open & you'll see all kinds of folders.
Find the Mywebsearch folder & open it. Find the folder 1.bin Right click once on that folder & left click past.
Close all opened windows & restart the system.
The program will function again without an error message.
More troubles? Post your question here.
Mike
Nov 13, 2008 | Compaq Presario 5000 PC Desktop
M3plugin.dll
Fiend your solution direct from mercury. Here is your solution.....
http://www.mercury.com/motherboard/prob676ijt65/solution
aamknr-7
Oct 30, 2008 | Mercury P4VM800M7 Motherboard
Error in c:\program\MYWEBS~1\1.bin\M3PLUGIN.DLL Missing Entry: UPP
when start computer the error message always pop-up Error in c:\program\MYWEBS~1\1.bin\M3PLUGIN.DLL Missing Entry is there an solutions
Oct 18, 2008 | Intel Motherboard
Error on start up
Hi parkin802, just follow these instruction:
Right click on the start button & slide up to & left click on search. In the search windows under All or part of the file name: type in m3plugin.dll
Than under Look in: click the drop down menu & click on C: Click search. Once the file is found right click on it once & slide to & left click copy. Right click once on the start button, slide up to & left click on Explorer. Left click on the + sign next to Program Files. Click the + sign next to MyWebSearch. Click the + sign next to Bar. Right click once on the 1.bin folder & slide to & left click past. The m3plugin.dll file will than be copied into the correct folder. Re-start you're PC. All done..
Enjoy!
Mike
Aug 13, 2008 | Intel Motherboard
Aug 02, 2008 | Intel Motherboard
M3plugin.dll
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.
pentium iii windows XP
the specified module could not be found m3plugin.dll it appears on startup on windows xp and i want to fix it
Jul 28, 2008 | Intel Motherboard
M3plugin.dll
progra-1maywebs/bar/8.bin/mwbar and 8.bin/m3plugin.dll .may problem with computer
Jun 02, 2008 | Intel Motherboard
Intel Motherboard Logo
116 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
