Question about Miele Novotronic Premier 500 Front Load Washer
Leak from tap at front of machine
The machine is leaking from the overflow tap at the front of the machine as soon as it is switched on. I have replaced the 3 part filter, but it continues to leak. Does anyone have any suggestions as to what the problem may be? Actual macine is Premier Novo - W842
  • ellisedward Nov 27, 2008
    That was exactly the problem, unfortunately I only discovered this when the Miele technician turned; scared me with talk of expensive pumps which may be needed; then 30 seconds later said it was ok he had cleaned the filter housing with an old toothbrush and it was completely sorted.......Oh and could I pay him £96 please.
    Hopefully others will benefit from your reply.
  • Guy Adriaensen
    Guy Adriaensen Jul 22, 2014
    Had the same problem. Cleaned the filter with an old toothbrush and.... OK. Thanks for the information.
    New Friend:
  • 128 Answers
The filter may not be sitting right in its slot - an obstacle may be keeping the filter from being seated all the way - once the filter is fully seated, it blocks the water to the front tap
Posted on Nov 27, 2008
My dishwasher is leaking from the bottom of the front door. I can't seem to get to the drain filter. Can that be removed? I think there may be a clog in it.
If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
Nov 21, 2015 | Dishwashers
Washer leaks
There is also a discharge lint filter on the front lower left that has to seal properly. If the water appears only when washing, you can probably eliminate leaking from the water supply side up to the solenoids controlling the water. The most likely source is a leak in the rubber section between the tub and the front door, a leak in the seal between the door and the washer, a leak or overflow in the soap dispenser, or a leak in the discharge side components. You could probably figure out the source if you could view these areas during a cycle, but that would require some disassembly of the cabinet so that you would need to know what you were doing.
Jul 13, 2014 | LG WM2101H Front Load Washer
What would cause fuel to leak out the overflow?
sticking float get a screw driver tap float bowl with handle gently
May 12, 2014 | 2006 kawasaki KLR 650
Electrolux dishwasher ESF6242, 911 236 182. Before the program was complete, the drain pump went into constant operation and the Error code i30 flashes, denoting 'water in the base' according to...
You have had a water overflow or leak which has triggered your flood switch. You need to disconnect the machine and pull it out. Throw plenty of towls on the floor and tilt machine back to empty the water from the base.
Hard to say where the overflow or leak is from. You need to reconnect machine while it is out of cabinet and run the machine to see if you can pin point a leak. Sometimes a burst drain hose.
Otherwise the front and side panels may need to be removed as the leak may be internal.
Other time a faulty PCB, faulty inlet solenoid which sticks or a faulty pressure switch or clogged pressure hose are the reasons for machine overflowing. Bad door seals can also cause machine to leak.
Therefore, there are a raft of items which can cause machine to overflow or leak.
Sep 08, 2011 | Dishwashers
Samsung washer is leaking water from under the front of the machine. not from the door. the drain pump works.
after it leaks, place machine on its side, look for wet spot, may be popped off hose or leak at pump, or rarely cracked drum if plastic.
Sep 02, 2009 | Samsung WF328AA Front Load Washer
Awm8143 FA code
Service manual say FA is "aquastop failure- check aquastop switch", (aquastop switch is flood switch located in base of machine), however looking at the parts view of this machine, it doesn't seem to have a flood switch-odd.
F9 is an overflow problem- manual says to check pressure switch.
Both faults seem to indicate either a leak or overflow problem- remove rear panel and check base for any water, which would indicate a leak.
If OK, next step would be to remove front panel (remove wire and spring from around door seal, remove 2 screws holding door lock, remove 3 screws along base- front panel comes off by pulling down and out towards you-can be a bit tight)
Pressure switch is located just above door lock-it has the black tube going to it- remove tube and blow into switch-you should hear it click.
Also check the chamber that the other end of the tube connects to on the bottom front of tub- this chamber can get blocked up and cause overfill problems.
Please note- always disconnect from power supply before attempting any repairs. If in any doubt, best to leave for an expert.
Good luck!!
Aug 11, 2009 | Whirlpool AWM8143 Front Load Washer
Fuel leak underneath bike
Most likely comes from the carburetor's overflow tube.Start looking in there to rule out the possibility of overflowing.If it is so you need carbs cleaning and adjusting.
Jun 06, 2009 | 2000 Honda NSR 125
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak
Did you check the drain hose?
Jun 25, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer overflowing
Clean out the peat trap by the front right side of the machine.
Apr 07, 2007 | Frigidaire FEX831CS Top Load Stacked...
Miele Novotronic Premier 500 Front Load Washer Logo
436 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
