Question about Toshiba Televison & Video
How do I access the menu on my toshiba md20f12 tv without a remote control?
Theres no menu button. How do I get to the menu without a remote control?
snakehead
  • 1074 Answers
SOURCE: Is there a way to access the T.V. menu without a remote?
YES YOU HAVE TO PRESS THE CHANNEL UP AND VOLUME UP TOGETHER OR THE CHANNEL DOWN AND VOLUME TOGETHER.THEN THE MENU WILL APPEAR AND DO WHAT YOU WANT TO AFTER,GOOD LUCK
Posted on Mar 26, 2007
  • 298 Answers
A universal remote with all the bells and whistles and
the right working code for your TV, Buttons like
menu, enter,tv.vid,pip, etc
Posted on Nov 20, 2007
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
SOURCE: Phillips PC7225 Menu
Found it!
I have a Philips universal remote. After trying half of the codes for Philips TVs, I came up with one which allowed access to the SETUP menu. It was 0621. This allowed me to run the auto channel setup, as well as fix some of the other functions. I don't know if this works with all remotes, but if you try different codes, you should get lucky. I'm sure it helps if you have a SETUP button on your remote.
Posted on Mar 22, 2009
SOURCE: My Sanyo TV remote AV button has failed. Is
Why would I tell you how I fixed my problem if I have to pay you to tell me.
Posted on Oct 06, 2009
How do I access the menu from the tv touch panel as the remote isn't working
Hi Susan,
There is a menu button in almost every tv's touch panel. Please press it to access the menu.
Unfortunately if your TV does not have a menu button, there is no way you can access the menu without a remote control.
Jun 30, 2015 | Televison & Video
Access menu without remote on Toshiba 27AF44
You can follow the option of searching the internet for any of several suppliers of OEM replacement remotes. The problem with universal remotes is that not all functions of the OEM remote are replicated.
Dec 19, 2013 | Toshiba 27AF44 27" TV
How do I unlock the 'panel lock' of my Toshiba Regza without remote control?
Hello
To unlock the panel lock of Toshiba TV, follow this.
Press the "Menu" button on the remote control, and scroll until you come to the "Preferences" menu. Select "Parental Control and Locks," then press "OK." If your TV does not have a "Preferences" menu, go directly to the "Locks" menu.
Enter the four-digit PIN that you selected when you turned the Panel Lock feature on. You may have to scroll up or down to access this area
Press the "Up" or "Down" buttons on the remote until you reach the Panel Lock feature. Move the cursor to select "Off," and press "OK."
Mar 24, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
How can i access the menu without the remote control?
On older Televisions such as the one you have listed, you cannot access those menus without a remote control. Just to make sure I skimmed the user manual found here. The only suggestion I have is to get a universal remote with a menu button. Dont forget to check with your other remotes to see if they have universal functionality. Most receivers (surround sound units) have multi-function remotes. Also check your satellite or cable remotes to see if they have universal functions. You can tell, because they will have multiple buttons that say things like "TV, AUX, CABLE, ETC" If so, you can program one of these remotes (or grab one at most electronics stores to program) and have your menu available to you.
Also, check the link to make sure there isnt some functionality hidden away that I didnt see.
Cheers!
Feb 23, 2011 | Toshiba MW20F52 20" TV/DVD/VCR Combo TV
Channel search on toshiba 27afx54 tv without remote control
Hello
There is no MRNU button on the front panel of your Toshiba TV. So it is impossible to tune it manually. You must have its remote control to select MENU options. OK.
Jan 02, 2011 | Toshiba 27AFX54 TV
I have a toshiba 27a33 without a remote and i am unable to change the tv/video settings. is there any way i am able to change the setting manually without a remote? Thank you.
Hello
Sorry. Your TVs front panel has no menu button to press. The only way to chane it to AV/TV, cand be done with its remote control which ahs that button to press. You just buy one new remote control, of get the present one repaired. OK.
Dec 06, 2010 | Toshiba 27A33 27" TV
Toshiba 27A41 27" TV Remote is lost. Need to change the input. Can I do this using the buttons on the TV? Can I program my DirectTV remote to change the input?
You can't chage it with your Direct TV remote control. If there is menu button in front of the tv, just go through the menu, and see the vedio options. From there you can change the input selection. If there is no menu button, you can't do anything without the help of remote control handset.
Oct 15, 2010 | Toshiba 27A41 27" TV
How do I access the input avi without the remote
hello Smith_Bradle. you need to find a remote control, there is not TV/VIDEO control menu on front panel where you can access between the inputs.
Watching video input
You can use the TV/VIDEO button on the remote control to view a signal
coming from other devices, such as VCRs or video disc players that
may be connected to your TV.
jkahangwa
Jun 25, 2010 | Toshiba 27A34 27" TV
Toshiba 24AF44
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Mar 16, 2008 | Toshiba 24AF45 24" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
