Question about Husky Air Tools & Compressors
I need a owners/parts manual for a husky H1504st compressor
4 Suggested Answers
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
digritz
  • 530 Answers
SOURCE: Need Manual for Husky Model 41214 Air Compressor
I can give you all the relevant data and specifications. I hope that is enough for you. Otherwise your going to have to go to Home Depot and try to get them to get or perhaps if you bought it from them copy one they have.
As for the Husky Tools web site it now redirects you to Home Depot.
Description:
1.5 Gallon Low Profile air Compressor. 1 Running HP, 135 Max PSI, Oil Free. Portable Lightweight Design with onboard storage. 2.0 SCFM at 90 PSI, 3.0 SCFM at 40 PSI.Ideal for Inflation, Cleaning and Fastening. 13 piece accessory kit included.
  • 1 Running HP, 135 MAX PSI , Oil Free
  • 2.0 SCFM at 90 PSI , 3.0 SCFM at 40 PSI
  • Portable Lightweight Design with onboard storage
  • Ideal for Inflation, Cleaning and Fastening
  • MFG Brand Name : Husky
  • MFG Model # : 41214
  • MFG Part # : 41214
Specs:
  • Amperage : 8 A
  • Assembled Depth (In Inches) : 16 in
  • Assembled Height (In Inches) : 17.5 in
  • Assembled Weight (In LBS) : 32.5 lb
  • Assembled Width (In Inches) : 14.5 in
  • Energy Star Compliant : No
  • Fuel Type : Electric
  • Height : 19.5 in
  • Horsepower : 1 hp
  • Maximum Pressure : 135 psi
  • Tank Capacity : 1.5 gal (US)
  • Voltage Rating : 120 V.
  • Width : 16.5 in
I have a large source to search for items like manuals and so far I have found only one Husky compressor manual. However I will keep looking. If I find it I will let you know. In the mean time if there is something you need to know more specific about you compressor please just ask and I'll get you an answer ASAP.
Hope this helps and Happy Holidays to you and yours.
Posted on Dec 21, 2009
Testimonial: "Thank you so much for responding. I am sure your information will do the trick. Thanks again the Happy Holidays!!!"
SOURCE: I have an 60 Gallon Air Compressor Husky Pro, no
Read the owners manual,look at the motor label
20Amp is usually for 2HP and may work for your 3.2
Look at full load rating on motor. You won't need a
breaker that high.
You will need 12 ga wire and 20 amp breaker min.
two wire 240 volt circuit.
It should be wired for the higher voltage,if not look at the
inside of the small motor cover and move the terminals
to the two pole rating. Expensive to run at 115volt
Posted on Nov 25, 2010
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
2004 Sym Husky 125 battery location
Hi, Tony for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Sym, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2004 Sym Husky 125 battery location Google Search
Sym Husky 125 HELP
Sym PA12B Service Manual
Sym HUSKY 125 cc 1999 Parts
Sym Husky 125 Euro 2004
Apr 03, 2015 | 2004 Sym Husky 125
How do you replace a belt on ***** air comprester
Most modles you can either loosen the pump or the motor and slide them together. the belt should roll right off.
Sep 15, 2014 | Husky Air Compressor. 2 Gal. Portable...
Need a manual for 80 gallon 4hp husky air compressor model hs7810
Go to the Campbell-Hausfeld website at http://www.chpower.com/, under the 'Service & Support' tab select 'Manuals/Parts List'. Search for your model number and you'll be presented with the parts lists and manuals for that line of compressors.
Feb 28, 2013 | Air Tools & Compressors
Looking for manuals for husky air compressor model FP204500AV
The manual and parts breakdown for your compressor can be found at: http://www.chpower.com/IMAGES/pdfs/manual02/608800_1102.pdf
If that doesn't work look for it on the Campbell-Hausfeld homepage at http://www.chpower.com/ under Service and Support. They have been working on the site so some links are not working correctly.
Your compressor is an oil-less type that has very little for you to do as far as service. Mostly you just have to keep it clean and occasionally drain the water from the tank. The frequency of that is dependent on where you are (humidity levels in your area) and how ofter you use it.
May 22, 2012 | Air Tools & Compressors
I have lost my manual to a husky pro 60 gal.air compressor and I need to add more oil, can someone tell me what oil ,seems that i used synthetic 10-30 initialy
either use air compressor engine oil,. or search out a new owners manual from online,. the details will be in there..
Best regards
Ck
Jan 05, 2011 | Campbell Hausfeld Air Tools & Compressors
Need to find out how to replace belt on WL65 cambell hausfeld air compressor
Not sure how easy it will be to locate repair instructions if they are not in your manual. However maybe the diagram of the pump is all you need. Just click on the first link below. It will open up the pump diagram. #14 is the belt.
I also included the link to the site where you can get a look a at the parts list and order parts for your compressor.
Hope something here helps.
If not please let me know and I'll try and describe the proccess for the belt remove to you.
Pump diagram:
http://www.mastertoolrepair.com/images/WL390100-Pump.jpg
Compressor diagram and parts list:
http://www.mastertoolrepair.com/wl650003-wl650102-wl650102aj-wl650202-wl650601-p-28707.html
Pump parts list:
http://www.mastertoolrepair.com/wl390100-p-17694.html
Nov 19, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
433 people viewed this question
Top Husky Air Tools & Compressors Experts
Lawrence Oravetz
Gil Shultz
ray gallant
Are you a Husky Air Tool and Compressor Expert? Answer questions, earn points and help others
