Question about Whirlpool Dryers
Whirlpool LE6880XSN1 heats up but will not dry clothes
SOURCE: Clothes dryer not heating
Hi I have a top vent Kenmore dryer. That seems to be heating up on and off. I can see the glow plus trying to ignite the gas I think what do you think is wrong..kj
Posted on Aug 28, 2008
david04928
  • 102 Answers
SOURCE: whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Posted on Mar 16, 2009
dniro592006
  • 121 Answers
SOURCE: Whirlpool Estate Dryer TGDS840JQ1 dryer runs but
when you say heat up is it at least getting warm...
you may have a igniter gone bad or your thermostat may have failed... your igniter is what has to ignite the gas to burn to make it hot. If its electric then your heating coil has failed and needs to be replaced
Posted on Jun 09, 2009
  • 16 Answers
SOURCE: Have to run dryer twice to get clothes dried
also check the exhaust outside of the house, i had birds nest in mine
Posted on Nov 01, 2009
  • 66 Answers
SOURCE: Whirlpool Duet dryer not drying like it used to
If your duet isn't heating properly and you have taken care of the lint problem then you could have one of two problems. Either you have a bad heating element or you have a bad fuse or temperature sensor.
If your dryer is not heating at all then it is most likely the fuse or temp sensor. If it is heating and just not enough it is probably a bad heating element.
Both problems would require a repairman to come and fix normally, however if you believe it is the heating element that can usually be replaced by the homeowner without too much trouble. Just make sure to ask where it is located from whatever place you but the new element from.
Posted on Dec 12, 2009
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
My whirlpool thin twin dryer will heat but clothes will not dry
Could be a venting problem, the damp warm air needs to be vented from the machine for the clothes to dry, if it is not venting properly the clothes will not dry. Have a look to see if your vent pipe is blocked of kinked.
Dec 14, 2013 | Whirlpool LTE6234D Top Load Stacked...
My Whirlpool dryer tumbles but no heat. The clothes dry after along period of time and that is when i finally feel some heat.
Probably needs a good cleaning. If it was me I would remove the filter housing and do a through cleanup. make sure the vent going outside is not blocked. The dryer must have adequate airflow to work well.
BEFORE AND AFTER
Oct 03, 2012 | Whirlpool Dryers
My dryer won't dry my clothes
clean out lint filter check the vent hose make sure you are getting a air flow out your vent hose if not its blocked inside no air no dry it need air to dry cloths heat only will not dry plenty of air heat quicker drying
Nov 27, 2011 | Whirlpool Dryers
I have a Whirlpool duet washer and dryer. The dryer is not working well. the ligts come on and it spins but it doesn't dry the clothes, what can the problem be?
Is it heating or not? Is this gas or electric? The first thing to check is your vent and clean the lint filter. Then you should check the heating element and the thermal fuses if it is not heating (assuming electric). If it is heating and you're not getting dry clothes then your venting must have issues. Good luck.
May 02, 2011 | Whirlpool Dryers
My dryer does not dry clothes
i would start by checking the thermal fuse and then the heating element itself.
Jul 28, 2010 | Whirlpool LER4634J Electric Dryer
Dryer heats up but doesn't dry clothes take 3 hours after restarting 3 times to dry 3 articles of clothing.
It's not your heating element. Your venting system is clogged. Like mine was. You'll need to take care of this ASAP and from then on at least once a year. It is a fire hazard. Not only that if left this way It can kill your heating element.
Oct 15, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
122 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
