Question about Canon imageRUNNER 400S Copier
Toner how do you remove the old toner cartridge before inserting a new one
  • dmcnealy Oct 28, 2008
    Thanks for your help.
    Problem Solver:
  • 11 Answers
Open front toner door, it's on the top right of machine. Pull old cartridge out, pull orange tape off end of new cartridge and slide it in.
Posted on Oct 28, 2008
Printer wont recognize toner cartridge
Just 3 questions:
Are you sure that the new cartridge is the proper one for your printer?
Is it correcly inserted?
Did you remove all stickers it might have?
Jul 08, 2015 | Office Equipment & Supplies
How to replace toner cartridge
-Open the front cover
-pull the old toner cartridge out.
-Remove the new toner cartridge from its bag
-Thoroughly shake the cartridge 5 or 6 times to distribute the toner evenly inside the cartridge.
-Thoroughly shake the cartridge to assure maximum copies per cartridge.
-Remove the paper protecting the toner cartridge by pulling the packing tape.
-Hold the toner cartridge by the handle and slowly insert the cartridge into the opening in the printer.
-Tabs on the sides of the cartridge and corresponding grooves within the printer will guide the cartridge into the correct position until it locks into place completely.
-close the front cover.Make sure that the cover is securely closed.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Dec 13, 2012 | Samsung SCX-6320F All-In-One Laser Printer
How to install printer catridge
Locate Empty Toner Cartridge
  • Turn off your Epson C900 printer and unplug it from your computer and from the electrical socket. Open the left-side panel of your C900 printer and locate the toner cartridge you want to replace. Epson has labeled each of the four cartridges.
Remove Old Toner Cartridge
  • Stick a finger in each of the holes in the empty toner cartridge. Pinch your fingers together and then slide the cartridge out from the printer's interior.
Insert New Toner Cartridge
  • Remove the new toner cartridge from its packaging and shake it vigorously to remix any settled toner. Take the cover off of the new cartridge by lifting it up and out to the right. Slide the new toner cartridge into the empty slot in your C900 printer. Close the left-side panel of your C900.
Oct 07, 2012 | Epson AcuLaser C900 laser toner
How to replace catridge
Oct 07, 2012 | Epson AcuLaser C900 Printer
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
I tried replacing the printer toner-I get a message saying "Cartridge error. Put black toner cartridge back in"
Remove the "new" cartridge, and re-insert the "old" cartridge, to see if _only_ the "new" cartridge causes the error.
Otherwise, take the printer to a qualified technician.
Jan 23, 2010 | Brother MFC 7840W Printer
How do i change the print cartridge?
Replacing the print cartridge
  1. Open the print cartridge door, and remove the old print cartridge. CAUTION: To prevent damage to the print cartridge, minimize its exposure to direct light by covering it with a sheet of paper. Figure 1: Removing the print cartridge c01174123.jpg
  2. Remove the new print cartridge from the packaging. CAUTION: To prevent damage to the print cartridge, hold the print cartridge at each end.
  3. Pull the tab until all the tape is removed from the cartridge. Put the tab in the print cartridge box to return for recycling. Figure 2: Removing the sealing tape c01211568.jpg
  4. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge. Figure 3: Shaking the print cartridge c01211569.jpg
  5. Insert the print cartridge in the device and close the print cartridge door. Figure 4: Inserting the print cartridge c01174125.jpg CAUTION: If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric.
NOTE: When toner is low, faded or light areas appear on the printed page. You might be able to temporarily improve print quality by redistributing the toner. To redistribute the toner, remove the cartridge from the device and gently rock it from front to back.
Sep 13, 2009 | HP Office Equipment & Supplies
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Problem with changing the Toner Copier Cartridge
F2 has to do with a toner sensor not working. It could be the replacement cartridge is missing something. Make sure you use a genuine Sharp toner cartridge and that should take care of the problem.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Mita DC-1205 Copier
Open the front door... on the right is your toner. It is a cartridge that inserts long-ways (front to rear) into the machine, and should be white or ivory in color. DO NOT remove the old toner cartridge without having a replacement on hand. The new cartridge will have a plastic "cover" on it that assists in releasing the toner cartridge locking tab, and "seal" the old cartridge as you remove it from the copier. The cartridge opening is face down upon installation into the machine, and you may get some spillage if you remove it without the cover. DO NOT remove the new cartridges mylar seal until AFTER you install it in the machine!!! There should be a picture label inside the front cover showing how to replace the cartridge. And there is a pictorial diagram on each new toner cartridge box also detailing this.
Use only MITA DC 1205/1255/1415/1435/1455 toner, OEM #MTA37041013. Should run you about $12-$14 per cartridge retail, or cheaper if shopping around (I sell them for $11.99). Do not use copystar brand for the same equipment. Although it's the same toner, the shape of the cartridge is slightly altered, and may not "fit" into the machine. I forget how it goes, either Copystar will work in Mita, and not the other way around, or vice-versa. Either way, better safe than sorry.
Oct 24, 2007 | Office Equipment & Supplies
Canon imageRUNNER 400S Copier Logo
old marine
old marine
