Question about Canon Pixma MX420 All-In-One Printer
Pimna mx420 won't scan
Canon pixma mx420 won't scan to computer
ferow_18
  • 24 Answers
SOURCE: Canon pixma mp 250 won't
Hi there.. i understand that you're having troubles printing from your computer because of that error message.. dont worry im here to help you out with that..
Here's what you can do:
  1. At the device or at the electrical outlet, disconnect the power cord or adapter (while the printer is turned on).
  2. Wait approximately ten to twenty seconds and then reconnect the power cord.
  3. Wait until the device has completed its cycling process before submitting another job request.
normally the reason why it is saying that error message its because the printer is not responding so that's why we will need to power reset you printer..
If you have any other questions, dont hesitate to reply on this message.. thanks and Good Luck!
Posted on Jun 01, 2011
SOURCE: canon pixma mp220
I had the same problem, and this is the fix.
1. Go to Canon's website and find the "Drivers and Downloads" section. From there, you will need to specify the subcategories of your hardware, and then your specific model (for example: Hybrid (i.e.-Printer & Scanner), Inkjet, MP470 Series)
2. When you find the proper page for your model printer, select your operating system from the drop down list.
3. Scroll down the page. You will see all versions of the drivers and programs to download. Download the latest version of the driver. You should also download the "My Printer" program. This is useful for troubleshooting and maintenance.
4. Keep scrolling until you find the "MP Navigator" program. This is a very important program, and is necessary for the scanner to operate properly. Download this program.
5. One MP Navigator is downloaded, verify that the scanner will use this program when it operates. To do this, go to the Start menu, click on Control Panel, click on Scanners and Cameras, click the printer that you will be using, then click properties. Click the tab at the top that says "Events." You will then see a drop down menu with the options Save to PC, Save as PDF, etc. Verify for each option that your computer is either opening the MP Navigator program, or that the computer will prompt you on which program to open.
This should get your scanner working. Hope this helps!
Posted on Sep 15, 2009
Geekman
  • 32281 Answers
SOURCE: my canon pixma mx320
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Posted on Jul 26, 2011
  • 24 Answers
SOURCE: canon pixma mx 700
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Posted on Aug 16, 2011
Angel Bird
  • 287 Answers
SOURCE: I just got my new
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually when the printer is not actually load the cartridge it shows error 5100
To solve this error follow the given steps:-
First of all turn off printer and remove both the cartridges from the printer, Now use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches, Return the cartridges and turn on the printer.Error will be removed.
Let me know If you have any more Confusion, questions or issue regarding your problem
I hope this solution helps you. Thank you for using FixYa!
Posted on Aug 20, 2011
Does this machine scan in PDF format? The only options I can find are JPEg etc, but not PDF.
In the manual it shows how to scan PDF's to the computer.
25392751-ul5qn2zlk5rxhwup3qg3kxin-3-0.png The manual is online with Canon USA and can be downloaded for free.
Canon Support Drivers PIXMA MX420
Jan 31, 2015 | Canon Pixma MX420 All-In-One Printer
I HAVE THE MX420 WHATS THE APP THAT I HAVE TO DOWNLOAD TO PRINT
If you don't have the original installation disc, you can go to the manufacturer's website and download the software you'll need. This page has the driver and software.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx420#DriversAndSoftware
If you plan on using it wirelessly, you might need to be plugged directly into your computer when doing this initial installation. The cable should have come with the printer and has a USB connection for your computer and the other end will go in the back of the printer. Follow the steps that should be there after you download the file. It's not an "app" you need, it's the "software". Good luck! Canon Support Drivers PIXMA MX420
Jan 01, 2015 | Canon Pixma MX420 All-In-One Printer
My Canon MX420 All in one printer will print but not scan. I just got it out of the shop for another isssue; do I need to download another program?
Hi my cannon MX 420 wouldn't scan if I tried to use the button on the printer. However if I opened the printer file from control panel, there was an option for scanning, which worked great. In the scanning options box read and choose each time you scan. Hope this helps
Jun 16, 2014 | Canon Pixma MX420 All-In-One Printer
Why does my MX420 stop printing halfway?
Hi . If copies are doing fine maybe is a network or drivers issue
May 17, 2017 | Canon Pixma MX420 All-In-One Printer
Canon pixma mx420 scanner menu doesn't load
Uninstall the Software from the computer completely and go to http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx420#DriversAndSoftware
to download the software again. make sure you delete the old one first through "control Panel" Uninstall Program, etc. Also make sure your printer isn't connected to the computer until after the software has finished installing. Then plug in the printer and see if the menus will show up. let me know how it goes..hope this helps!
Jun 16, 2012 | Canon PIXMA MX420
Won't connect to iPad
IPads can't connect to a printer. Wired or by WiFi. You will have to email your document to your regular computer, then print it from the computer
Dec 28, 2011 | Canon Pixma MX420 All-In-One Printer
I just got my new printer Canon Pixma MX420 yesterday. When I turn on the printer, the error 5100 occurs. The scree of the pritner askes me to see the manual, but I can find the solution page. I dont know...
Aug 20, 2011 | Canon Pixma MX420 All-In-One Printer
Where to find serial number on cannon Pixma mxx420
You can find the serial number on a PIXMA MX420 All-In-One printer by opening the scanning unit cover and locating the serial number on a sticker in front of the print head.
Jun 22, 2011 | Canon Pixma MX420 All-In-One Printer
Canon Pixma MX420 All-In-One Printer Logo
1,624 people viewed this question
old marine
old marine
