Question about Porter Cable C2002 150 Psi 6 Gal Compressor
How to find manifold parts for porter cable c2002 Type 3 copressor
Its plastic washer type thing inside the pressure turn nob.
4 Suggested Answers
  • 2428 Answers
SOURCE: My porter cable C2002 Type
I have the same unit and had the same problem Its a good little mechine but the problem is the houseings for the gauges when you are loading the mechine can get hit and move up and this will bend the neddle on the gauge and make it hang up . You can carefuly remove the lense with a small screwdriver it just snaps on and off then gentaly bend the neddle pointer backand snap the lense cover back on and it should work again . Just be carefuly when you transport the mechine not to let the base of the gauges touch anything
Posted on Aug 30, 2011
  • 3 Answers
SOURCE: Model C2002 type 3 Air
File a complaint with porta cable and also know these compressors have a three year limited warranty. If you have a receipt like I did when mine started leaking only after about a year and light duty and hardly used too.. Anyway , I returned mine for full credit where I bought it. I might try one more but thinking bosch this time. Bosch makes one about the same size and might be made better quality.. I;m going to check their ratings.
Posted on Dec 13, 2011
cody_lance
I have same problem with my PC2002 type 3 AC and come to find out after removing the know for the regulator, inside there is a spring(remove it),underneath is a seal with a nipple in the center that is used to let the air though. It is made of plastic(so mine broke).Tough job is finding that seal.
Posted on Mar 19, 2012
My Porter Cable pancake outlet regulator doesn't seem to work.
If your quick coupler is not jammed up, (remove & test) and assuming you are pulling the regulator knob out to adjust the pressure and it is not stripped, you will need a new manifold kit.
There are about 6 versions of this unit so you will need model and type to get the correct part. There are no individual regulator parts available for this unit.
Jul 02, 2013 | Porter Cable C2002 150 Psi 6 Gal...
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Zero outlet pressure Porter Cable C2002 type 3
The collar tends to break off of the plastic tip and falls inside the spring. I just repaired mine by epoxying the tip to a modified closet-maid wire shelf clip and stacking (3) #78 o-rings on the tip. The clip mod was a tap with a 1/4" chisel to remove the shelf hook, leaving just the "square" screw receiver. As it happened, the screw recess was the same size as the tip. Put a little epoxy into the screw recess, press the tip into it, clean any excess and let it set for an hour. Slip on the o-rings, align all the parts, thread the regulator cover back into place. O-rings are in the plumbing section at Home Depot, epoxy usually near the paints, clips near the wire shelving. Best wishes.
May 19, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Model C2002 type 3 Air leaks from the back of the knob when I turn the regulator to allow pressure to flow to the hose. Air will flow to the hose but I quickly loose pressure due to the air leaking from...
Sep 18, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable C2002 Type 3 air compressor will build air in the tank, but I am not getting a pressure reading on the regulator gauge.
Aug 30, 2011 | Porter Cable C2002 150 Psi 6 Gal...
The regulator knob is broke. Where can I get a replacement? Replacement parts diagrams do not show the knob as replacement part.
You can't buy the regulator knob as a seperate part, you have to buy the entire manifold; Porter Cable part number N003001. Shop around on parts sites as these cost around $70 plus any shipping and handling. Depending on how often you have to change the regulated pressure output it may not be worth replacing.
Jan 20, 2011 | Porter Cable C2002 150 Psi 6 Gal...
My porter cable c2002 150 psi gal compressor the pressure regulator is always set at 0 and no air at outlets, but the tank is fill of air 150psi. what could be the problem
According to Porter-Cable (Delta) themselves, they had lots of bad regulators on these compressors. I'm waiting for one myself. Same issue
Jul 10, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Worked fine previously. Now when turned on the tank pressure comes up normally . However, the regulated pressure gauge reads zero and there is no airflow.
What happens when you twist the regulated pressure knob, as you would to increase the regulated pressure? Does the knob turn? Does it turn until it stops, but still reads zero? If so, it sounds like the regulator pressure spring is broken. That's inside the regulator, and you will probably have to replace the regulator.
Jun 16, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Porter Cable C2002 150 Psi 6 Gal Compressor Logo
399 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
