Question about Daewoo KOR-860A Microwave Oven
Daewoo DMW 900 DCG 900 Watts Microwave
My oven doesn't work , its internal rotating motor is not rotating and it also doesn't heat or cook but it accept all the commands.
5 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: daewoo microwave that won't cook
More than likely a door switch inside the unit is misalligned or faulty. Crack it open and check for proper allignment and good open/closed circuits with a VOM.
Posted on Sep 24, 2008
MicrowaveSvc
  • 8871 Answers
SOURCE: Daewoo KOC-1B0K no interior light and turntable not rotating
Looking at the service manual at our site, that would be a failure in the "motor relay" (relay 4) or one of the components that drive that relay, such as transistor Q8.
The part numbers for this relay are OJ-SS-124LM (generic) 5SC0101405 (Daeweoo).
Posted on Jan 29, 2009
MicrowaveSvc
  • 8871 Answers
SOURCE: Daewoo rotating base
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
Posted on May 26, 2009
  • 4088 Answers
SOURCE: light comes on and turntable moves but not cooking
Fuse blown? Needs to make high voltage for the magnetron. A blown fuse usually means trouble in the high voltage system (a shorted HV diode or maybe a bad stirrer [metal fan-like device] bearing which is located just above the interior case under the waveguide assembly). If suspect, replace the stirrer as a unit. If fuse looks ok, maybe bad door interlock switch or not being operated by door closure.
Posted on Aug 03, 2009
heatman101
  • 43501 Answers
SOURCE: Thermal fuse needs replacing.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hjkj
Posted on Sep 30, 2010
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
R-820js wont heat
see this causes and fix it .God bless you
f the microwave will not work at all, make sure power is on at the outlet and test the electrical cord. Test the fuse and replace it if it is faulty. Also check the door to make sure it closes properly. Test and, if needed, replace the fan. If the oven doesn't cook or cooks only intermittently but the display is on, check the door interlock switch, the thermal cutout (see the Applaince Controls Fix-It Guide), and the fan, replacing parts that don't pass the test.
If the oven keeps blowing fuses, check for a faulty door interlock or monitor switch.
Oct 02, 2012 | Sharp R820JS 900 Watts Convection ...
Hi when we using oven, its light is on and the try is also rotating, but it is not cooking means the heating effect is not coming.
heatman101
Jul 24, 2011 | LG LMH1517 1000 Watts Convection /...
Ge spacemaker xl1800
Basic Microwave Oven TroubleshootingTips
heatman101][]=--=
May 02, 2010 | GE XL1800 1100 Watts Microwave Oven
Microoven model 860A is not getting heated
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
heatman101
hjkj
Apr 18, 2009 | Daewoo KOR-630A Microwave Oven
Not working
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician, as repairing microwaves is a pretty risky job.
Oct 05, 2008 | Microwave Ovens
Daewoo KOR-860A Microwave Oven Logo
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
