Question about GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel
Is the GE over the range microwave model# jvm1530wmc a charcoal filter or outside vent
Does it have a charcoal filter
Illeagle
  • 525 Answers
SOURCE: microwave message says to replace
External vent systems have the charcoal filter removed, generally at the time of installation, as it is not needed for this application.
The charcoal filter removes odors from internal recycled airflow.
There should be an aluminum grease filter that you can remove to clean in a warm soapy solution, let dry, and reinstall.
Posted on May 27, 2008
SOURCE: purchased a microwave model JVM1750DMIBB
Thank you for responding - we visited our local HHgregg store for clarification of our 'problem'.....
Posted on Jun 27, 2008
  • 4 Answers
SOURCE: need help selecting proper charcoal filter
It's Part No. WB06X10359.
Posted on Jul 18, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: The Charcoal Filter (JX81C) used for non-vented GE
This of course assumes that your oven has the optional Recirculating Charcoal Filter Kit (part # JX81C available here) already installed.
From the owner's manual here:
Posted on Nov 29, 2009
  • 25 Answers
SOURCE: How do I change the Charcoal filter on my GE
the charcoal filter is either in the top of the microwave or on the bottom, but you can order from APDEPOT.COM, Repairclinic.com or searspartsdirect.com
Posted on Feb 23, 2011
We have a sharp 1480 and have to mount it with no outside vent. Can this be done? patqlt@verizon.net
Most of these over the range models come already set up for unvented operation. That is, set up for use with no outside vent. The oven will filter air through the a charcoal filter inside the upper grill and the vent covers underneath. If you ever wish to change the operation to allow the unit to vent outdoors, you need to change the direction of the blower fan assemby inside the top of the microwave oven. These instructions should be listed in the installation manual that comes with your oven.
Aug 16, 2010 | Sharp R-1480 Microwave Oven
Samsung Microwave for over the range vent issue
Most over the range models can be vented to the outside, or they can be set up (sometimes requiring a special adapter) to recirculate with a charcoal filter.
It depends on the model, and you would of course have to consult the installation instructions to be sure.
You can download many Samsung over the range microwave installation instructions here.
You may need the free DJVU viewer to view or print your manual.
You can order Samsung parts here.
Dec 05, 2009 | Samsung Microwave Ovens
Replacing old over-range microwave
Are the grease filters clean?
If you have a charcoal filter, make sure it's not clogged, too. These must be replaced, not cleaned.
In most cases, GE can recommend a "drop-in" replacement oven if you tell them the model number.
They should be able to tell you if larger ones will work in your current slot.
GE Customer Service is here.
Jun 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need a charcoal filter
The GE spec sheets for what is the right charcoal filter are incorrect. You will never find the right one. I have this same microwave and had same problem. I called a local appliance company and they gave me Part No. WB06X10359 and when I googled this part it was not the right dimensions. I finally found the perfect solution. Go to www.rangehoodsfilter.com (Filter Factory-TTN Inc.) and they are customing making the filter for me. I spoke to Dave this morning from Filter Facotry and he's making me one with the following dimensions - 5 7/8" x 13 1/4" x 1/4". The cost is $16.95. If this fits I will order more. The more you order, the cost per unit goes down.
Jun 03, 2009 | GE Spacemaker JVM1540 Microwave Oven
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have a 12-year old GE Spacemaker with integrated vent. It just doesn't pull. Vents to outside, out the back. Screens are clean. Anyone else find this vent inherently weak?
These vents are not vents per se, they are nothing but charcoal coated foam filters, they are not intended to take the place of a vent.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave message says to replace charcoal filter. User manual states charcoal filter is used if unit is not vented outside. Our unit is vented outside
May 27, 2008 | GE Microwave Ovens
GE Spacemaker 1.5 Cu. Ft. Over-the-Range Microwave - CleanSteel Logo
96 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
