Programming television with my Sky+ remote
I have recently bought a new 37"LG5010 LCD television and when using my Sky+ remote a can not adjust the volume.
  • kelvin_ball8 Nov 10, 2008
    my remote will not control tv even though i have tried all of the codes.
  • Anonymous Nov 25, 2008
    Had a LG5010.. Tried all possible codes and SKY+ remote is not working on this...
Posted on Dec 01, 2008
The screen size on my tv needs adjusting . How do I do this thro' mt Sky remote?
The screen size is also called the aspect of the TV. look in your menu for aspect ratio.
Dec 15, 2011 | LG 37LG50 37 in. LCD HDTV
Tryin to progam my sky remote to tv got a 32in alba new one the sky remote has flashed tiwce still no joy its has been working ok for 2 months got up today would not work
Firstly, try changing the batteries. If you've already changed then the remote has probably lost the TV code.
If you can post your exact Alba Model number, I will post the correct code and programming instructions for you.
It would also be useful if you can post you Sky remote version number - it's on a sticker in the battery compartment. I need to know if it's Rev 8, Rev 6, Rev 4 or just RC1600/00.
Oct 15, 2010 | Albatron LWX-30AMS-3 30 in. HDTV-Ready LCD...
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Need a code so that i can operate my LG tv. model no. 37LG5010 using my sky remote.
Firstly you may need to identify which version of remote control you have, versions that are dated pre 2002 may not operate the more modern TV's and a new remote control will be needed To see which version you have, open the battery cover on the back of the Sky remote and look at the text on the sticker it will state ‘Sky rev’ (or Sky+ rev or Sky HD rev), followed by a number, such as 4, 6 or 8. This number indicates the version of your Remote Control.
Version 4: May 2001 (Sky+ introduced)
Codes are 0065, or 0405,or 0037
Version 6: March 2004
Code are 0065, or 0405, or 0037
Version 8: January 2006 (includes all current Sky+HD remote controls)
Code are 1293, or 1206, or 0206
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Enter the code for the TV listings above (Use the 4 digit codes), the red light will flash twice if a valid code has been entered. Press the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes above or continue with this process by continuously pressing "TV" then "Standy" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code
Apr 25, 2010 | LG 37LG50 37 in. LCD HDTV
I need a 4 didit code for my remote for my neon telly
Neon are a brand made by Cello.
This is from their FAQ page here
http://www.celloelectronics.com/faqs#
"There are no codes available for the Sky remote controls, however due to a high demand from customer’s Cello have been working on a new remote control design which will be supplied with the latest range of TV’s as well as being available to purchase from Contrast Technology. This modern design will work with all 73 and 51 series LCD TV’s that use the RC08 and 09 remote handset and will operate the following satellite boxes:
  • Sky Digital
  • Sky Plus
  • Sky HD Plus"
Apr 18, 2010 | Televison & Video
Remote to opperate sky volume
please follow the steps below:
TV
RED + SELECT
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 17, 2009 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Just bought a ONN LCD TELIVISION MODEL AO37ZID from asda, looking for a 4 digit code for sky remote
Got this one to work on both the 37" AO37ZID and the smaller 17" Onn branded A017LC
Sky code: 0527
Jun 29, 2008 | Televison & Video
Wharfedale tv
GO ONTO YOUR SKY SETTINGS AND ADJUST FOR 16,9 THAT SHOULD CURE YOUR PROBLEM
Feb 15, 2008 | Televison & Video
37" aquos
It sounds like it may be n demo mode. Check the inbuilt menus and check this is turned off.
Nov 24, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Programming new remote
Hi
check this out
http://www.akai.com/contact.asp
ask them they might email them to you.
Good Luck
Nov 17, 2007 | Akai LCT3701AD 37 in. LCD Television
Televison & Video Logo
415 people viewed this question
Top Televison & Video Experts
Electro Med Services...
