Question about RCA 25205RE1 Phone
RCA 25205 wont answer correctly
I've got an RCA 25205 2 line phone.(purchased yesterday 10-26-08 from Staples) I can not get the answering machine portion to work. I've recorded all of the messages ie work private, after hours for both lines and confirmed they are recorded. Work and after hours times are set. Answer button is on. OGA config is set to timed. Time and date are set and correct. When you call in to either line 1 or 2, the default message comes on and plays and then does not let you leave a message. It blinks that there is a new call and CID works. I have even replaced this phone with another RCA 25205. Exactly the same problem. What's wrong???
  • 1 more comment
  • branchs Nov 07, 2008
    I can not get the answering machine to work. I've recorded all of the messages ie work private, after hours for both lines and confirmed they are recorded. Work and after hours times are set. Answer button is on. OGA config is set to timed. Time and date are set and correct. When you call in to either line 1 or 2, the default message comes on and plays and then does not let you leave a message. It blinks that there is a new call and CID works.
  • Anonymous Mar 20, 2014
    phone mailbox is set up but when someone else calls and we do not answer, it does a default message that "the subscriber has not set up their mailbox" doesn't allow the caller to leave the message
  • Anonymous Mar 28, 2014
    need to add my own personal message on answer machine like office hours etc
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Posted on Dec 03, 2008
I am trying to setup voice mail on a RCA ViSYS 2-Line Phone (25255RE2), and i cannot figure it out.
Here's the manual for your 2-line phone:
http://www.rca4business.com/products/pc/pdf/instruction-book/25255RE2.pdf
refer to pages 40-43 of your manual for "Answering System Operation."
To enable your Answering System, press and hold the "ans sys" button for 2 seconds.
The "ans sys" button indicator will flash.
To disable your Answering System, press and hold the same button for 2 seconds.
The "ans sys" button indicator will go off.
May 16, 2011 | RCA ViSYS 2-Line Speakerphone
I do not have the manual for my two line RCA Visys phone, and I need to change the message on the answering machine, can you help me?
RCA makes several different 2-line phone systems. Select the model you have from
http://www.rca4business.com/products/pc/viewCategories.asp?idCategory=28
Feb 09, 2011 | RCA ViSYS 2-Line Speakerphone
HOW DO I TURN OFF THE ANSWERING MACHINE FOR THE RCA VISYS MODEL 5RE1A..?????
Briefly press the Answer L1 or L2 button, it displays the answering status on LCD. For example, L1: ANSWER OFF.
To change the status, press and hold the Answer L1. Unit will display and announce the new status of the answering system.
Nov 02, 2010 | RCA ViSYS 2-Line Speakerphone
Phone keep initializing
I had the same problem (constant initializing with dropped lines, no dial tone, etc) with my RCA Visys 2-line phone (model 25205) after owning it about 3 months, and could not find a solution on the Web, so I called RCA customer service. They said this problem is not user-fixable and they gave me an RMA# to return it. They will send a replacement phone as soon as you fax the receipt, your name, problem with the phone, etc.. Then when you get the replacement phone you send them the bad phone.
Aug 31, 2010 | RCA ViSYS 2-Line Speakerphone
I just purchased this phone and hooked everything up correctly, but the Line in use light is on and the handheld states line in use and the answering machine will not respond to pick up messages. What is...
The phone will do this if it isn't (or thinks it isn't) connected to a working phone jack. Try a known good phone (corded type) in the jack to verify that in fact there is dial tone there. Also make sure that the line cord is firmly plugged in at both ends until the latching tabs snap into place. Sometimes it's just a poor connection because the plug isn't all the way in. You can also try another line cord. Bad ones do pop up sometimes.
If everything is correct with the phone jack, take the phone back to the store for an exchange. You have a dud.
Mar 05, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Can't turn off the answering machine on the RCA 25205
it is simple. press menu and hold and it will most likely give you directions, step by-step. there should be on/off switch
Jul 31, 2009 | RCA 25205RE1 Phone
RCA 25205 2-line corded pnone answering machine won't answer
Record the message for both line one and line 2, see if that helps.
Sep 03, 2008 | Lands Phones
RCA 25205 Visys will not record message
Called the company. There is a misprint in the instructions.
In the section titled "Out-Going Announcement RECORD" on last step it says Press Exit to stop recording. It should have said Press Sel/Save.
I did this and it worked.
Repeat for Line 2 if you are doing both lines.
Next thing is to make sure you go right to the section titled "Configure Out-Going Announcement" and select the right type of message you want callers to hear for each line.
Worked like a charm and took 3 seconds to get 2 different personal messages on the machine.
Aug 07, 2008 | RCA 25205RE1 Phone
Phone is not recording all messages left
The 25414RE3 isn't the model with the answering machine. The one that has the answering machine is the 25415RE3.
As for the problem, does the answering machine part of the unit actually pick up the line? Does it announce your pre-recorded message? Does it just not record the caller's response?
Sep 08, 2007 | RCA 25414RE3 Corded Phone
RCA 25205RE1 Phone Logo
647 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
