Question about Hammering
Need a wiring diagram for a onan 175 kw generator diagram # 0612-6692 or 0612-6694
erickg
  • 116 Answers
SOURCE: Oil type for Onan 4000 generator
SAE 15W-40 is what i used to use
synthetic? not sure about that one there may be oil pres switch that could give you a problem.
Posted on Apr 17, 2009
  • 12 Answers
SOURCE: Have an Onan RV generator. WHat kind of oil do I
30W
Posted on Apr 30, 2009
  • 6 Answers
SOURCE: Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Posted on Sep 28, 2009
  • 16 Answers
SOURCE: need onan marquis 5000 model 5bgmfa26105f wiring
Give me to full model and spec # and I will email you a service manual.
Posted on Jan 15, 2010
SOURCE: Need battery for Onan 6500 Generator
I have searched but cannot actually find what type male of battery it uses, other than it is a Lead Acid Battery. Now with lead Acid batteries, it is the actual Capacity, in Both Amperage output, and Physical capacity. So based upon that ANY 12 V DC Wet Cell battery of the SAME Physical size, and CURRENT capacity will work. Look on the actual battery itself, it WILL/Should have identifying marks written on it. Get one the same, it is NOT all that critical.
Posted on May 23, 2010
Testimonial: "This helps alot..The manual did not give specs on the battery. All I could find was 14L-A2 "
Onan JB 7.5 KW with Transfer panel battery trickler lasted 10 years on deep cycle now only 2 years?
[PDF]Onan Master Service Manual.pdf
michaelstractors.com/forum/.../Onan%20Master%20Service%20Manual....
Jun 28, 1978 - rated at seventeen and one half (17.5) kilowatts or less. ... of an Onanengine generator set, automatic transfer switch, running time meter and .
Oct 12, 2015 | Electrical Supplies
Onan 12.5 JC-3CR
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Mar 02, 2013 | Onan propane generator set, 15.6 kva, 12.5...
Wiring diagram for onan 12.5 JC-3CR generator
Did you ever find a schematic? If not I can probably help you. Question is how do I get it to you :)
Need onan marquis 5000 model 5bgmfa26105f wiring
Nov 04, 2009 | Watts Onan Portable Generator - 5000 ,...
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
Hammering Logo
81 people viewed this question
Top Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
