Question about HP Compaq Presario v3000z Notebook
Laptop shuts down often when using battery power
My daughter has a V3000 that is approx 2 years old. For the past several months, when she is using battery power, the laptop will shut down. She is using the bulky extended life battery. Is this a battery problem? Or something else?
Thanks
Steve
    Brigadier General:
  • 6,966 Answers
Often, this would be a battery problem given the age of the laptop. A way to verify is if the AC adapter/charger is plugged in and the problem persist, then it would be "something else".
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 27, 2008
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
My company uses Panasonic Toughbook CF-18. We have ones that are over a year old, over 6 month old, and even just a few months old. In the past few weeks we started experiencing a problem where the units...
The battery interface has broken away from main board at the limit stop. Requires trained tech to repair. You mentioned these are new.. Cf 18 have been discontinued for years. Are these cf19's
Sep 08, 2011 | Panasonic Toughbook 18 CF-18NDHZX-VM...
For the past three weeks i recognised that my laptop would cut off without being shut down and takes a while when i try to start it up again even though its plugged in the the power outlet. Can you tell...
I believe that it might be because the laptop is overheating. Just like a car, when something is worked too hard it will shut itself off. Considering that the battery is dead, I suppose that it's over 2-3 years old. Which can be a prime candidate for overheating.
This can be remedied by getting a laptop docking fan. They are inexpensive. Usually about $20-25. This reduces heat, and will give you a better user experience. Including, not shutting off on you.
Please Rate.
Thanks.
Jul 07, 2011 | Computers & Internet
Compaq Presario Laptop half screen issue
no photos of the screen presented.
so all i can do is guess what it looks like,
its so old HP has no info on it. legacy PC, called retired.
i guess 10 years old
2007
so one side is dead, black screen right?
and if you shine flash light on the black side, is there data there or not?????????????????
the v3000 is a CCLF back lamps (edge)
and last 20,000 hours max, (very very short life)
so when one side fails. it goes black
the bulb does or its inverter, supply does.
all do this everyone,
all go dim
then blink
then die, or are random starting.
just like a florecent light in say your garage, same deal. same gas tube.
use the flash light, see its not really BLANK IS IT
only the black lamp quit.
endless post here on topic,
in the year 2010 most of these ended and are now all LED
ending all this pain.
Sep 20, 2017 | HP 435768-001 - Compaq Presario C300...
My Compaq Presario V3000 laptop will not power up.
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Dec 04, 2009 | HP Compaq Presario V3000T Notebook
Dell Vostro 1000 shut down and won't turn back on
nope, it is your dc power regulator board. you will note this happens if the battery is in or out of the laptop. that is the key test. some regulators are on the main board and some are seperate for this reason. I think the vostro though is on the main board. A little board re-work will resolve this issue after replacing some components, but this is way beyond a home user's ability.. trust me on this. Sorry for the bad news. Thanks!
mrstan
Aug 29, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
BATTERY NOT CHARGING
Try replacing the battery, i think the battery is defective.
May 09, 2009 | Acer Aspire One PC Notebook
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Jul 22, 2008 | Computers & Internet
HP Compaq Presario v3000z Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
